Lights always on.
Had this issue for some years now but I've just put up with it as I've not been able to figure it out.
Sidelights, rear lights and dash lights are always on with the ignition on as if the stalk is turned onto the first position but it's definitely in the off position.
If you turn the stalk onto sidelights it makes all of the lights slightly brighter.
I've tried another indicator stalk and checked all of the dash fuses but can't find any fault.
Just wondering if anyone would have any ideas?
Sticking relay?
(22-12-2017, 08:04 AM)Mighty306 Wrote: Sticking relay?
Which relay is it for the lights?
Phase 2 fusebox btw.
yeh check the relay. Maybe the stalk is also a bit sticky?
no relay for the side light circuit
un plug the column switch and try a replacement Wink
GTI6 Info
(22-12-2017, 01:26 PM)cully Wrote: no relay for the side light circuit
So you think it can only be the stalk?
Thanks for the help so far.
stalk is the only feed to the side lights and dash lights unless you have a wiring fault
GTI6 Info
Any damage to the clocks on the back?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
If I unplug the stalk completely it still lights up with the ignition on.
So a wiring fault somewhere it seems?
un plug the panel light dimmer switch by your right knee check no one has teed ito the cables for gauge lights and are back feeding a supply
no one has wired day running lights?
GTI6 Info
(23-12-2017, 01:02 PM)cully Wrote: un plug the panel light dimmer switch by your right knee check no one has teed ito the cables for gauge lights and are back feeding a supply
When I first got the car in 2009 it never did this which is the strange thing.
It used to have a Toad alarm which I cut out as it was always playing up when I'd turn the ignition off and lock the car.
Pic of the wiring behind the panel, the black mess is due to the dash being flocked some years ago.
Does anyone know what the green connection is for?
https://www.flickr.com/gp/149954682@N06/81x6Ls
Has anyone done anything around the car stereo wiring?
As Cully say's it sounds like something is back feeding the system.
(26-12-2017, 09:03 PM)DeeTurbo Wrote: Has anyone done anything around the car stereo wiring?
Not that I know of, I've not had a stereo in it at all for a few years as it's stripped out and loud from everything else.
Not sure on the plug, but its burnt.. Along with some of the wires where it joins the loom by the looks..
Sent from my LG-H870 using Tapatalk
Sorry I should have been clearer the burnt looking parts is actually overspray from the flocking.
I'll give it a clean up to make sure.
  Instrument lights, dash lights not working boggs 3 4,852 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  Odometer lights and clock lights inop bashbarnard 3 4,163 23-07-2014, 08:43 PM
Last Post: DarkInferno
  N/S Brake lights/Side Lights not working Grant 10 6,591 18-11-2013, 08:02 PM
Last Post: Grant
