Bottom aux belt pulley removal
Anyone got any tips for removing this given my recent situation with my cam pulleys... I tried removing it off the other day but it's not budging. I don't have any air tools, so it's pretty tricky.
It's a GTi6
I maybe wrong but get someone to put it in gear and foot brake on and try to undone it. I always use a impact gun so don't have any problem Smile
With wheel bolts in the hubs aswell otherwise you could break off the locating screw for the the disc lol
(19-10-2013, 10:44 PM)Tom Wrote: With wheel bolts in the hubs aswell otherwise you could break off the locating screw for the the disc lol
Yes I did this
(even though I knew about it I just forgot) haa
[Image: av5ym8.jpg]
locking pin in place, breaker bar and a 22mm socket. Done. They are bloody tight. I think they are 220nm?
(20-10-2013, 09:27 AM)Niall Wrote: locking pin in place, breaker bar and a 22mm socket. Done. They are bloody tight. I think they are 220nm?
Can't use the locking pins as the inlet pulley is snapped Wink
Correct me if im wrong but I think he means lock the flywheel.
Anyhow I wouldnt do it like that could damage the ring gear on flywheel. Or if the pin snaps you'll be taking the gearbox off to find the pieces
[Image: av5ym8.jpg]
On the aux belt pulley is a hole and at about 12 oclock is a locking hole. Bang a 8mm(?) drill bit in there and undo it. Dont need a belt on at all.
Ahh right. Thought u ment lock the flywheel through hole in side of block
[Image: av5ym8.jpg]
(20-10-2013, 10:39 AM)Niall Wrote: On the aux belt pulley is a hole and at about 12 oclock is a locking hole. Bang a 8mm(?) drill bit in there and undo it. Dont need a belt on at all.
Legend. I'll have a gander at it tomorrow, if that comes undone, off comes the head and I can start rebuilding it and I'll have the 6 back Big Grin
i wouldnt use the pin to undo the bolt as you risk delaminating the pulley
which will feck you up when you come to retime the engine as that is the only crank lock point
i would tend to use the teeth on the flywheel to lock the crank
(20-10-2013, 10:54 AM)cully Wrote: i would tend to use the teeth on the flywheel to lock the crank
+1
[Image: siggy1.jpg]
(20-10-2013, 10:54 AM)cully Wrote: i wouldnt use the pin to undo the bolt as you risk delaminating the pulley
How to you lock the crank with the flywheel? Does it involve dropping the gearbox off?
No there is an inspection cover in the top of the gear box directly above the fly wheel which is ideal for sticking a prybar in, get a mate to hold that whilst you undo the crank pulley.
Thanks Niall, I'll try that tomorrow when I can get hold of a breaker bar.
I got the pulley off by locking the flywheel. I tried with someone sat in the car and foot on brakes, but there was too much give. The flywheel method kept it solid!
Thanks lads Wink
breaker bar...jammed in ground.
then use starter!!
make sure fuel switch deactivated/coil pack off
  power steering belt not on the pulley properly jjenn20 2 2,139 06-04-2015, 01:29 PM
Last Post: jjenn20
  Pug1off or Lynx bottom pulley HDIkyle 16 7,855 05-12-2013, 09:03 PM
Last Post: miles
  Gti6 bottom pulley head scratcher Marcdimma 4 3,387 15-11-2013, 06:22 PM
Last Post: welshpug
