Pug1off or Lynx bottom pulley
Pug1off works out at £75 posted where as lynx is £89.99 not sure on post for that. Is there a great difference to warrent the prices?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
i think £89 is lynx's old price for the HDI bottom pulley
i have bought two lynx pulleys and both are running fine Wink
my bad should read what section youve posted in Doh
Well its for a xud I just put it in xu section by mistake. Is there any differences to warrent the price difference tho?
Blaze 1.6 Dead
lynx one may be anodised
Lynx ones are supposed to be better made although I've never seen a pug1off one up close so can't really comment.
Lynx will also probably do you a better price if you ask. They did for me Smile
BBM make the pug1off pulleys, but you can only buy from pug1off.
Rich W does do a small discount afaik.
Pugracing do them too.
I wouldn't use either. Bye bye oil pump chain if you rev too high....
JP
Interesting to read that as I have never had issues with mine and that rev's to 8500 rpm currently and the pulley does not come in contact with the pump chain, thats behind the end alloy cover
(02-12-2013, 07:04 PM)jammapic Wrote: I wouldn't use either. Bye bye oil pump chain if you rev too high....
Why? Cant see how it would effect it tbh!
dont see how the pully affects the chain other than the early engines with the friction drive sprocket
then only a loose bolt would
Less harmonic damping of the crank.
Miles, interesting. I've found two things by lightening the crank damping too much by use of very light pulleys and light flywheels.
1) snapped oil pump chains by vibration / surging
2) poor rpm pickup on the flywheel due to "jitter" on the crank revolution. I.e. Odd crank acceleration / deceleration characteristics.
JP
Whats happened to yours then jammapic. If so when did it happen?
287 Bhp N/A Big Grin
Built by Pug1Off
1/4 mile in 13.6
Now in french car mag
Chris, it kept happening I suspect it can be made worse with no power steering pump etc.
Put a stock pulley back on and it's sorted...
JP
if its happened to the same engine I would imagine its rather more than just a pulley at fault.
Interesting one, To be fair, the entire point of the pulley stock how it is is to prevent such harmonics / vibrations..but ive NEVER heard of people having real world issues with it on cars...
Its a big problem with tractors, aftermarket pulleys are fitted, and tractors simply snap cranks, have seen it time and time again...so interesting thoughts.
It's not as immediate an effect with cars, as they tend to only spend brief periods in the problem frequencies, as the rpms are always changing. Much more readily show with working engines which tend to be running within a few hundred rpm all the time.
Still, the damage it can eventually cause is undeniable. But then most car engines that are being tweaked probably won't be expected to do another 50k miles anyway.
Some reading for you, http://vibrationfree.co.uk/
  Lynx inlet barb Niall 0 1,675 26-06-2015, 08:09 PM
Last Post: Niall
  Gti6 bottom pulley head scratcher Marcdimma 4 3,497 15-11-2013, 06:22 PM
Last Post: welshpug
  Bottom aux belt pulley removal callumcull 16 9,354 21-10-2013, 07:57 PM
Last Post: Piggy
