bleeding fuel lines
right put a perfectly healthy engione into jj0063's shell today but its been a right bitch to bleed the fuel lines iv cranked for about an hour killing the battery lol.
iv done the usual cracked the injector, pumped the grenade, check the fuel housing, undone that banjo bolt between the pully and the housing with pl;enty of fuel coming out. Just cant get any fuel out the injectors.
Any suggestions or is it just a case of just keep trying. the engine ran sweet in the old car
Current cars
Subaru Impreza 2.0d - Daily
Check the o-ring in the sender unit and the connection on top?
the engine that we removed from the old shell had been running so the tank should be ok
Current cars
loosen the return banjo and pump the grenade until air stops coming out, then crank it over with all injectors loose
cheers mate ill give that a bash tomorrow.
any other ideas?
Current cars
Tow it, or try and bump it, seems to draw the fuel up easier than just cranking them on the starter.
[Image: sig.jpg]
Thanks mate il giv it a bash later
Current cars
have you defently got 12 volt to the stop solenoid? been there before my self on a dodgy solenoid i removed the plunger from it re fitted top of solenoid bleed then ok no problems.
  Bosch pump fuel lines and bits blinkyeatu 3 2,775 30-08-2015, 07:17 PM
Last Post: bashbarnard
  Fuel filter for 10mm lines bashbarnard 5 3,953 12-05-2015, 10:59 AM
Last Post: maxlee
  upgraded fuel lines ash23 11 8,085 14-08-2014, 02:28 PM
Last Post: Tom
