Ph3 bump strips on ph2
Do phase 3 bump strips fit a phase 2. I seen some today and they are rounded unlike the flat phase 2 ones. They also look a little narrower not sure if its because they're curved or actually narrower. Are they a direct replacement. I can't imagine peugeot redesigning all the crease part down the side of the car where the bump strip meets just to fit a curved one.
NO SMOKE NO POKEBig Grin
I've seen a few ph1 with the later ph3 bump strips, and they don't look rite as the ph1 has a indented line where the bottom of the earlier bump strip ends, looks totally out of place, so I would imagen the ph2 is the same. Some others on here may have a better answer.
(10-07-2013, 10:40 PM)underground375 Wrote: I've seen a few ph1 with the later ph3 bump strips, and they don't look rite as the ph1 has a indented line where the bottom of the earlier bump strip ends, looks totally out of place, so I would imagen the ph2 is the same. Some others on here may have a better answer.
That's what I was wondering about that indented line.
do it, i cant say ive ever noticed it looking odd when ive seen a ph2 with ph3 strips
(10-07-2013, 11:11 PM)4WayDiablo Wrote: do it, i cant say ive ever noticed it looking odd when ive seen a ph2 with ph3 strips
Ill try one piece of it on tomorrow and post how it looks.
Yeah be good to see a close up picture of it,
Yeah they are direct fit no problems. No line on the underside. I have ph3s on my ph2 6 sp first hand experience.
The wing strip dosnt line up 100% but isnt noticable
(11-07-2013, 09:32 AM)puglove Wrote: Yeah they are direct fit no problems. No line on the underside. I have ph3s on my ph2 6 sp first hand experience.
I test fitted the wing one and realised that so didn't want to pull the rest off and break the clips to find out they didn't fit either and end up with none.
Thanks ill put them on then and try and work something out with the wing one.
I found that if you cut the clip holders off the back of the strip the "no more nails" the clips on the back of the strip in the correct place works well lol
  Ph3 bump strips? underground375 3 2,468 20-08-2013, 09:53 PM
Last Post: underground375
  Bump Strips lazareth1 7 4,584 07-06-2013, 01:14 PM
Last Post: lazareth1
  door bump strips 306newbie 9 5,433 16-04-2013, 04:40 PM
Last Post: megwan
