Bump Strips
Hi guys,
Do the bump strips on a 306 come off easily? Thinking of replacing the black plastic bump strips on my car with the Ph3 colour coded ones.
Yes just rip them off. Then get new white clips off eBay.
If your careful & take your time (10-15mins aside) you can get them off nice and easy and save the clips, just use 2 very small screw drivers
That two put its more fun just ripping them off. If you want to save money scrap yard and harvest white clips.
Stay pulling them off towards front of the door then last 3 will slide of.
DO NOT Pull them off from the front of the door! Start from the rear as there is a clip at the front that is part of the bump strip and if you snap that off, they won't hold tight to the door and flop around... Noone wants a floppy...
(06-06-2013, 07:43 PM)Connor Wrote: DO NOT Pull them off from the front of the door! Start from the rear as there is a clip at the front that is part of the bump strip and if you snap that off, they won't hold tight to the door and flop around... Noone wants a floppy...
Other way round then sorry.
Cheers guys. A day in the scrap yard for me then Smile
  Ph3 bump strips? underground375 3 2,461 20-08-2013, 09:53 PM
Last Post: underground375
  Ph3 bump strips on ph2 Aaron _d95 8 5,256 11-07-2013, 12:44 PM
Last Post: puglove
  door bump strips 306newbie 9 5,401 16-04-2013, 04:40 PM
Last Post: megwan
