tapping into ally xantia manifold?
Gonna fit my xantia manifold instead of the adaptor. Just need to tap into it with some sort of pipe take off for the boost compensator
Questions are
What to use as a take off large bleed nipple, air line fitting..
And will using a tap/die be strong enough in the alloy or should I fit a helicoil into it?
Any barbed fitting is fine, and yes alloy is fine if you use front face, I drilled / tapped several outlets into mine
(30-06-2013, 01:31 PM)darrenjlobb Wrote: Any barbed fitting is fine, and yes alloy is fine if you use front face, I drilled / tapped several outlets into mine
Ok cheers have got some airline ends that have a edge on.was going to drill into the front as thats the thickest part.
Cheers
I tapped two bleed nipples in as a cheap option, no problems at all..
One for LDA, one for boost gauge. Useful for seeing loses from turbo to inlet but does require two gauges ideally.
I drilled and tapped the bolt on metal flange at the front as was easier to fit in the vice and meant if I wanted rid of them I could just bolt another one on
(30-06-2013, 03:57 PM)Sambarker Wrote: I drilled and tapped the bolt on metal flange at the front as was easier to fit in the vice and meant if I wanted rid of them I could just bolt another one on
Also avoids and chance of ally filings going down the intake.
I dont need to worry about that the manifolds off the car atm
  Tapping into boost pipes ginge191 7 5,413 06-09-2016, 11:40 PM
Last Post: toseland
  Xantia manifold gasket Nathan1305 2 3,174 06-04-2015, 07:57 AM
Last Post: Nathan1305
  Xantia manifold tight to master cylinder mikey b 8 5,312 25-02-2014, 09:14 PM
Last Post: padge
