Xantia manifold tight to master cylinder
Fitted my xantia manifold and it's bleedy tight to the
Master cylinder any one had this before thanks
I'm not sure if i'm just tired, but that doesn't make a great deal of sense to me. Can you edit your post with a bit of punctuation, and try to explain that a bit better please?
There is both a short and a long version of the that type of inlet manifold.
You can either try and find another one that is shorter, or get handy with the grinder to make some clearance.
Basically the manifold is tight to the master cylinder when it's on yep I will prob just get handy with the grinder
I'll have a look at mine at lunch
Mine was tight on 205 bend the brake line slightly and it fits now event still very tight but it's not touching it any more Smile
Heard of this before u can get a slight but of movement away from the master cylinder by adjusting the gearbox mount as it apparently slides left to right a bit when fitting
(24-02-2014, 08:56 PM)Nath140889 Wrote: Heard of this before u can get a slight but of movement away from the master cylinder by adjusting the gearbox mount as it apparently slides left to right a bit when fitting
Cool thanks will try this as well as grinding the manifold a little bit
I ran the xantia mani, was very close but never had issues, the 406 inlet mani is the shorter one, but imo dosent look as good.
  Xantia manifold gasket Nathan1305 2 3,066 06-04-2015, 07:57 AM
Last Post: Nathan1305
  Wanted xantia manifold mikey b 1 2,037 23-07-2013, 05:16 PM
Last Post: darrenjlobb
  tapping into ally xantia manifold? Jimbo 6 4,727 30-06-2013, 04:50 PM
Last Post: Jimbo
