Grinding noise
I have a grinding noise coming from the front drivers side wheel area. It is audible when turning left AND accelerating, not just one or the other.
Really confusing me, my first thoughts were driveshaft or wheel bearing but they both spin when turning, so surely would make the noise even when not accelerating. Or would being under load affect them?
[Image: 20120704_212316.jpg]
Pads ok?
CV boot loose? Or the clip for it? Remove wheel and inspect
S2 HDi >click<
154bhp
280lbs/ft
Wheel bearing my dt was like that and the bearing was f***ed
Wheel bearing I'd say, you'll not always get them by jacking the car up and spinning by hand, sometimes you have to put it in gear and spin it to get it to growl.
I'd also say wheel bearing, had the same on my old Bianca white DT & my old v70...
  Grinding noise after skidding on ice. Uberderv 14 6,495 21-03-2018, 06:39 PM
Last Post: Uberderv
  grinding brakes Chris_90 11 5,703 05-09-2014, 02:37 PM
Last Post: Chris_90
  Grinding on rear passenger wheels at slow speeds Jukie88 3 2,784 06-11-2013, 07:27 PM
Last Post: C2K
