grinding brakes
This is about my vento but all brakes are pretty much the same Wink
My front brakes seem to make a grinding noise once they have warmed up, pads are fine discs are fine both was brand new about 9,000miles ago, greased pads and sliders up made no difference, really don't no what can be causing it now apart from the pads them self's?
Any one able to shed some light on it?
Make of pads?
Not the backing disc or something?
try putting a smearing of copper slip on the back of the pads, if the noises continue then its the pads..........
He says he has greased the pads.
Maybe the pads...may not be
Mintex pads if I remember rightly could be wrong tho.
And yer greased backs of pads, sliders, we're the pad sits etc with copper grease to
Only think I can think it is, is the pads it's done it pretty much since I put them one, but I've lived with it, doesn't affect braking in any way can lock up easy enough with enough pressure, just annoying and to potential buyers sounds like brakes are f**ked Sad
Checked the brake piston hasnt got corrosion which is preventing it from fully retracting into into place?
I had this with my Mitsubishi Galant after it had been sat for about 6 months, drove home on night and the whole car was vibrating like mad, pulled over and the front passenger disk was glowing red like you see in race cars, also i had completely lost my brakes as i imagine the fluid had boiled behind the piston
(04-09-2014, 10:34 PM)Lolben91 Wrote: Checked the brake piston hasnt got corrosion which is preventing it from fully retracting into into place?
I don't think thats the issue don't have no silly hot brakes or anything like that.
I've tried to change the pads but euro car parts have given me the wrong pads twice so I've now given up if I go back I'll end up knocking the guy out with them! Angry
Have you done this?
http://www.cliosport.net/forum/showthrea...ging+discs
Wow...
[Image: mcetg0.png]
"A little bit of knowledge is a dangerous thing..." as the saying goes.
(05-09-2014, 10:32 AM)JJ0063 Wrote: Have you done this?
Shit I best go double check Wink lol
On a serious note I'm not that daft (hard to believe I no) Tongue
  Grinding noise after skidding on ice. Uberderv 14 6,518 21-03-2018, 06:39 PM
Last Post: Uberderv
  Grinding on rear passenger wheels at slow speeds Jukie88 3 2,790 06-11-2013, 07:27 PM
Last Post: C2K
  Strange/horrible grinding sound Jtrigga 3 2,564 09-08-2013, 07:52 PM
Last Post: John1.4
