Grinding on rear passenger wheels at slow speeds
Right noticed this morning as I set off for work that the rear left hand side is making a grinding sound !! It's ok at speed but when pulling upto a junction it makes a very bad grinding sound now as its dark I can't really investigate much more ive abandoned my drive to work so just wondering what I should look for ??
Something stuck in disc
Rear wheel bearing
Trailing arm bushes ??
Shock collapsed so wheel hits arch it's not touching ATM but car is very low at back so low infact I'm not sure wether its dropped any more :-(
Any help would be very much apreciated
I don't actually know but in the daylight could not get some to look/listen while you drive forward and back slowly??
U sure the inner brake pad hasnt just worn out
[Image: av5ym8.jpg]
Worn out/missing/catching brake pad.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
  Uneven brake drag on rear wheels balkan_bozo 2 4,117 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Grinding noise after skidding on ice. Uberderv 14 6,875 21-03-2018, 06:39 PM
Last Post: Uberderv
  rear wheels rubbing gary.jennings050580 7 4,180 18-01-2015, 08:57 AM
Last Post: cully
