Oil line block connector - advice needed
Looking at getting a braided line made up for my T25 and want to check that the spare connector I have is suitable.
Normally the piece that threads into the block is able to slide up and down the line, however I've got one where its been slightly bent so the piece won't move up and down at all (but can spin so will still screw into the thread in the block).
Will this still be ok to use?
You can kind of see what I mean in these photos:
1) Normal connector, can slide up and down line.
[Image: 12466614.jpg]
2) Comparison, you can see its jammed at end due to a kink in line.
[Image: 12466617.jpg]
3) Another comparison.
[Image: 12466619.jpg]
I've tried bending the line back into shape but as its inside of the connector where the damage is it hasn't been possible. I've also tried freeing it up by hitting the piece with a chisel whilst clamping the line.
It's also worth mentioning the car I got it off had a turbo full of oil. That car however ran fine for years and I witnessed the turbo die on it (so I then bought it as spares) so it probably isn't related.
so long as the end flange is ok I cant see an issue....thats where it seals
  Bulkhead to dashboard wiring connector 306Puggy 7 5,196 22-10-2014, 09:18 AM
Last Post: Cbray2003
  Help/Advice needed for Wiring in 205 STDT Tacho Counter silverzx 11 11,630 24-06-2013, 08:44 PM
Last Post: ozonehostile
  advice needed { white smoke } bayley 19 11,841 26-03-2013, 08:19 PM
Last Post: bayley
