Threads: 80
1
Car Model/Spec: 1999 306 Meridian 1.9 TD
Attempting to lower my rear beam but the Arb is siezed pretty well, tried winding a bolt and it stripped the threads, don't have a slide hammer either.
Any way of lowering it without removing the Arb?
Cheers
No smoke, No poke!
Threads: 42
28
which side? should be doing the ths, with the correct threaded bolt
you can lower without removing arb yes.
Threads: 80
1
One side the threads are completely corroded and the one I tried just stripped, was the correct thread on the bolt, but it stripped, how would I go about lowering without removing the Arb?
No smoke, No poke!
Threads: 371
29
Car Model/Spec: ford fiesta
You cant arb has to be removed. If its that bad likely that the beam is shagged as well anyway.
Threads: 42
28
08-04-2015, 12:42 PM
(This post was last modified: 08-04-2015, 12:42 PM by welshpug.)
you dont need to remove the arb to lower.
what thread were you using?
Threads: 26
4
Majority of arbs that I've tried to remove with a bolt have been useless, stick as big a diameter of a punch that you can fit in and a couple of good heavy thumps and it will come out.
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
Depending on the year of the axle some flags used m12x1.5 and from what ive come across the later axles used a m12.1.75
But there is no need to remove it to lower it.
Threads: 371
29
How do you get the torsion bars out without removing arb? I thought arb plate is in the way. Obviously I could be wrong and as Stef is saying it I probably am.
Threads: 80
1
Gave up in the end, think my beam is goosed any way because it looks like there is some camber on the back!
No smoke, No poke!
Threads: 371
29
(08-04-2015, 02:21 PM)Stef205 Wrote: (08-04-2015, 01:34 PM)bashbarnard Wrote: How do you get the torsion bars out without removing arb? I thought arb plate is in the way. Obviously I could be wrong and as Stef is saying it I probably am.
Just turn the flag so it's out of your way, it's very accessible with them out the way
Now I feel like an idiot. Of course you could!!
