Anti roll bar bushes ARB
Rainbow
I was wandering what symptoms do you get with anti roll bar bushes ARB.
I have changed the P bushes and drop links things are much better now. But the anti roll bar had to be moved over a bit to stop it catching. It's a bit better but still needs moving over a bit more. So will the anti roll bar bushes make any difference?
Is there anything that stops the anti roll bar moving to one side to much? I will a just again more but just want to know if things can still move?
I have 19mm ones for the 306 hdi.
Thanks
The bushes had a tab if you like and there is sort of notch of sorts on the ARB to stop it moving side to side...
So the bushes may well be worn
Mine knocked badly
What they like to change?
(10-04-2014, 06:03 PM)kentiiboii Wrote: What they like to change?
The bushes are not to bad to change. It's getting the anti roll bar straight so being on a ramp makes it easier to see underneath.
I have never had issues with getting the bar straight!!?
The bushes locate themselves in the arb, so you cant get it wrong!
Can be a bit fiddly though...easy to remove, with little tiny bit of lube, easy to slide into place, tricky bit is putting tension on the bush clamp while bolting it on
It's a bit of an ass ache.
They don't seem to close around the bar all that well which can make it difficult getting the clamp over and lining up the bolts.
Not the worst job in the world though.
Cheers, I have access to a pit anyway so happy days.
it's fine as long as you take droplinks off . .Smile
not that bad a job, you trying to mercedes sprinter ones, thats annoying on your own :/
  Rear anti roll bar Tidoh2016 3 3,371 02-03-2018, 12:18 PM
Last Post: Tidoh2016
  Front Anti Roll bar and bush few questions titch 17 9,627 18-05-2015, 11:06 AM
Last Post: titch
  URGENT! anti roll bar stuck! philpemberton94 12 7,277 08-04-2015, 04:08 PM
Last Post: bashbarnard
