It'll pass. The attention to detail the car gets, it would be rude not to!
The Racetractor. The End.
01-12-2014, 01:01 PM
Fail on something silly like a sidelight that blows on the way to the test centre I reckon. Cant be any major fails!
01-12-2014, 01:35 PM
Tax disc holder in window screen, or something so daft you don't think about it
01-12-2014, 06:13 PM
tax disc came out as soon as I could!
All lights in order, gave the inside a good clean as it was filthy, good impressions and all that. Also, topped up fluids, fitted a relay so the arduino comes on with ignition and removed the DRLs fuse, just to avoid arguing over it!! Seem good lads there...they have a mk2 escort, landy, FTO, Beetle and other maad projects there, so into their modded stuff! Only real concerns are the new o/s drivshaft spits out a little grease where the metal clip holds it on. So have wiped it all off for now. And then NEW gearbox shaft seals are leaking So wiped that down too. other than that, its all above board...so should be fine oh, I will be reducing max fuel and setting a throttle stop tomorrow just for protection!! In other news.....I want more boost. So if MOT is fine...time to wind up the boost! Wishes for more power...
02-12-2014, 09:28 PM
Some mot prep...
Throttle stop "adjustment" [attachment=20415] Arduino battery secure... [attachment=20416] Last min wash... [attachment=20417] Also turned fuel down half turn!! Wishes for more power...
02-12-2014, 09:33 PM
A) You're still running the Arduino on a separate battery?
B) What is that abomination of wiring C) If that battery has a small hole on it for a vent pipe (most do) then get it hooked up and outside the car. Some REALLY picky testers will fail you for that.
02-12-2014, 10:13 PM
(02-12-2014, 09:33 PM)Niall Wrote: A) You're still running the Arduino on a separate battery? yes and yes. Dont like it, then come fix it!! It was all dark last minute wiring predyno when Ruan was here. 3 core wiring to the arduino in the front and a boost cable to the car battery to give common earth!! Its not in charging circuit so wont give off gasses I will be searching for more permanent solution after MOT obviously...as I hate that thing in me boot! Any help is VERY welcome to do that! Wishes for more power...
02-12-2014, 10:18 PM
So remind me, is this because you was getting some form of interference when it was running of the main battery?
03-12-2014, 09:55 AM
When I saw the pics of the voltage regs it looked like they had no caps or very tiny ones.
The circuit needs improving IMHO.
Yeah to both the above. Interference to signals when linked to car power supply.
Just small caps. Power supply side needs improving for sure. Bit beyond my knowlege, spent some time reading about capacitors and just drowned! So...MOT man just rang me......... Wishes for more power...
03-12-2014, 12:24 PM
03-12-2014, 01:04 PM
come on i hate cliffhangers at the best of times
03-12-2014, 01:29 PM
I'm betting it failed on the battery not being secure and a loose connection (jump cable).
03-12-2014, 03:52 PM
Fail on emissions due to blocked raccoon filter.
03-12-2014, 03:57 PM
Wrong colour.
Must be a ringer.
03-12-2014, 04:05 PM
Moonstone is always silver on the logbook lol.
03-12-2014, 04:09 PM
Well done.
Major CBA to run through 69 (lolz) pages... what the Arduino running? Matt-Rallye Wrote:Norledge for prime minister. Poodle Wrote:I reckon Norledge has got it on the head mind. Matt-Rallye Wrote:Norledge gets my vote tbh.
03-12-2014, 04:20 PM
Yes arduino works.
MOT guys were well impressed!! He said "technically I should fail it for no cat...but then I run a decat so meh" haha!! They got some epic projects going so we had some banter and chatted...ideal, a local garage to make friends with. Handy!! Wishes for more power...
03-12-2014, 04:22 PM
Yeah but it works doing what??
Ohhhhh ok comprends vous, thought it might be something a little more exciting.
03-12-2014, 04:41 PM
Got to love a friendly mot tester!
03-12-2014, 04:43 PM
(03-12-2014, 04:20 PM)Piggy Wrote: ideal, a local garage to make friends with. Handy!! Your MOT tester is your best friend. Once they understand you do all the work and they do free retests, bringing it back is just costing them money. Faults are pointed out and may be an advisory but more often not a fail. You must have made a very good impression
03-12-2014, 04:51 PM
Shiney engine bay and big turbo did the work for me!!
Arduino does do exciting stuff for me...makes boost. All the boost!! Wishes for more power...
03-12-2014, 08:09 PM
(03-12-2014, 04:41 PM)Niall Wrote: Got to love a friendly mot tester!Im a friendly mot tester in fact all 3 of us in our garage are. Ive met some right arseholes in my time though. Well done on the pass man. Always good to get a pass and a friendly garage.
04-12-2014, 03:48 PM
Good work mate, you bringing her to christmas meet then?
Im in minehead this weekend.
In other news... Still not sorted temp gauge, but oil light works only if you tap the dash so its obviously a poor connection. Must sort asap Coolant hasnt gone down at all since doing the head which is a refreshing change!! Tried advancing pump today a tad but it just clatters too much for my liking Need some dedicated setup time with someone. Wishes for more power...
04-12-2014, 06:04 PM
Oh and ordered some better quality shaft seals and some ASH silicone hose as the head to crank breather/oil drain hose is cracked and brittle and leaking. And Pug say they dont have any left.
Its time to stop the last two oil leaks!! Wishes for more power...
Users browsing this thread: 23 Guest(s)
