13-03-2012, 11:12 AM
Yea just let me know mate.
My stage 2 HDi project (Dyno results inside!)
13-03-2012, 12:28 PM
I'd be up for RR if your planning on doing it end of month or next month.
Should have FMIC on and with a bit of luck one of Dan's pins.
13-03-2012, 04:27 PM
RR is tomorrow bud
On another note.. it failed its mot but only on headlight clips were broken.. some superglue and cable ties later I now have 12 months MOT
14-03-2012, 01:32 PM
Ha nice. Ah that's an easy job at least, wouldn't fancy needing to do the mani gasket on my daily - would mean i had to finish it that day so couldn't sack it off if it pissed me off lol. :S
14-03-2012, 01:35 PM
Yeah, this is my daily lol so anything that gets done has a 1 day time limit lol..
Dyno time tonight!
14-03-2012, 09:05 PM
Awesome, get those results up!
14-03-2012, 11:30 PM
![]() ![]() ![]() ![]() Fairly pleased with the results too tbh, also have videos of mine, Connor and ruans cars which i'll be putting up soon! Have to say Ruans sounds epic on full chat! Mine didnt sound too shabby either tbh!
15-03-2012, 12:25 AM
There will be some controversy over what I say next:
Notice on the graph, it says "Driveline Efficiency 95%" - that means your driveline loses 5% power... Which isn't right for an FWD car, mine's identical - i.e. they didn't do a coast down test on the rollers. Which means if you do the maths... 141hp = 105% of the WHP figure... 1% = 141HP/105% 1% = 1.342 * 100% = Wheel Figure = 134.2HP 10% of 134.2 = 13.42 5% of 134.2 = 6.71 Power Loss @ 15% = 20.13 Wheel Figure + 15% Losses = Flywheel = 154.33HP Do the same with the torque figure of 251lb.ft which brings it to 273.7lb.ft torque... Which I'd say is MUCH closer to the actual figures... Generally it's accepted a FWD car will lose about 15%, RWD about 20% and AWD/4WD about 20-25% depending on how it's setup... At least, Dyno Dynamics "Shootout" rollers use these corrections...
15-03-2012, 09:17 AM
That seems to make a lot of sense, I did wonder why I didn't see any ATW figures on the graph... And from most Hdi dynos I've seen its generally been about 20bhp less ATW than the fly so your maths is pretty spot on
15-03-2012, 09:47 AM
If you do mine -
161/105 = 1.53 1.53*100 = 153.333HP ATW Makes much more sense like that...
15-03-2012, 11:06 AM
Good result that
15-03-2012, 11:18 AM
Midnightclub Wrote:Cheers mate I keep wondering what mine is making but knowing my luck, if I put it on a RR it will throw a rod!
15-03-2012, 11:47 AM
That's in NM... That's 251lbft...
15-03-2012, 11:59 AM
Although after correction it's closer to 270 like ruan said so still quite a lot of torque
15-03-2012, 12:20 PM
I have been thinking about it tbh.. Just need to work out exactly what i'd need and how much it'd cost.. From what i've read the best setup is the DT conversion but with an uprated pressure plate from sachs.. I'm still not entirely sure though tbh
15-03-2012, 02:28 PM
4WayDiablo Wrote:The fan only seems to be on half the time? Yeah for some stupid reason unknown to any of us it only kicked in at a certain RPM which is stupid as the inlet system is effectively not intercooled until the fan kicks in! I reckon it would've been higher if it'd been kept on the whole time
18-03-2012, 09:15 AM
Lovely sound quality there mate... Good results though, even if the dyno place was a bit half-baked.
I would say though, that this is my one issue with stage 2 HDi's - zero drama. 150something bhp and it looks less exciting on boost than a standard dt with a t2...
18-03-2012, 09:57 AM
Yeah.. it was f*cking loud there so the sound quality is shit haha..
I know what you mean but tbh I just love the way it drives atm
20-04-2012, 12:49 AM
more pics or GTFO..
| 306 Stage 2 HDi Progress/Project. | mcglynn | 139 | 117,832 |
31-12-2018, 02:09 AM Last Post: Allistairc123 |
| Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. | Matt-Rallye | 29 | 26,153 |
10-05-2017, 12:49 PM Last Post: Poodle |
| 306 2.1td inside [[[portuguese project]]] | fabiosilva16 | 47 | 46,907 |
30-01-2015, 12:56 PM Last Post: jonas306 |
