Black Phase 1 DTurbo = Win.
#31
Wish i got that intercooler kit now Sad
RED
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
It'll definitely be a 1 piece gasket.... All Turbo XUD9s are a one piece gasket, it's the NAs that aren't.
Nice one Ruan! Mills the place to go for a new one?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Not much of an update but replaced my tired air filter and adjusted pumps throttle/LDA some more.
1 - Old vs New
[Image: IMG_0803.jpg]
2 - Old vs New
[Image: IMG_0804.jpg]
3 - Fitted
[Image: IMG_0805.jpg]
4 - Fitted
[Image: IMG_0806.jpg]
5 - Fitted
[Image: IMG_0807.jpg]
6 - Bay
[Image: IMG_0808.jpg]
7 - Pump
[Image: IMG_0809.jpg]
8 - LDA
[Image: IMG_0811.jpg]
S14 Zenki Build
Looks good mate, the IC kit should be great, shouldn't need to hack the bumper up to get that in Smile
Get it fitted then, I still see a top mount in the pics ninja
Team Orange Engine Bay
mark_airey Wrote:Looks good mate, the IC kit should be great, shouldn't need to hack the bumper up to get that in Smile
Cheers mate, trying not to rush into the FMIC though. Need order a gasket (I'll do that now), and some 90* silicone bends.
S14 Zenki Build
Crack on then Tongue
silverzx Wrote:Cheers mate, trying not to rush into the FMIC though. Need order a gasket (I'll do that now), and some 90* silicone bends.
i've got one if you need one pal...
ginge191 Wrote:I've got one if you need one pal...
Inlet/exhaust one that is required IIRC for what they cost he would be as well just just get one Smile
sorry, i meant a 90* silicone :roll: my bad... and a piece of straight pipe if its any good..
I got a gasket from my local for £5 ~ something. So that's sorted.
Ginge, do you have one 90* bend silicone? Is it 2.25"? Big Grin
S14 Zenki Build
Are the breaks ok?
[Image: siggy1.jpg]
Bit of squealing when turning now and then but I'm sure that's them just bedding in. :thumbup:
S14 Zenki Build
Gave her a oil & filter service along with tweaking LDA some more and fine tuning.
Devil_Fuel & Connor were also kind enough to fit my 266's in the pouring rain on Saturday! Nice one lads!
Few updates & pic's below:
1 - Cleaned Inlet.
[Image: IMG_0757.jpg]
2 - De-badge (don't like it).
[Image: IMG_0769.jpg]
3 - De-badge (don't like it).
[Image: IMG_0770.jpg]
4 - LDA hanging on by couple threads.
[Image: IMG_0783.jpg]
5 - Inlet/Exhaust gasket for FMIC (says XUD7 but looks same)?
[Image: IMG_0828.jpg]
6 - Close up of ^ label.
[Image: IMG_0830.jpg]
7 - LDA pins from scrappy.
[Image: IMG_0831.jpg]
8 - Oil used on left, potential usable oil on right?
[Image: IMG_0832.jpg]
S14 Zenki Build
I recently ordered some gaskets for my dturbo, all BGA gaskets, and they all say XUD7 too, wouldn't worry about it Smile
Id say 15w40 was too thick, but seeing as you already have it, might as well use it lol
Passed MOT, so fresh 12 months on the old girl.
Ordered and received last bits I need to fit my FMIC.
Did some detailing. Mainly removing vegetable oil stains from the fuel tank area..
Running well on 25 psi. 8-)
1. TCut fuel cap area
[Image: th_P1030827.jpg]
2. TCut whole car
[Image: th_P1030826.jpg]
Turned out pretty well. :dance:
3. Before
[Image: th_P1030829.jpg]
4. After
[Image: th_P1030831.jpg]
5. After
[Image: th_P1030832.jpg]
Painted my inlet manifold red to match my pipes and silicone etc.
6. Xantia inlet
[Image: th_P1030834.jpg]
Gave some of the body a good seeing to
7. Wax & polish
[Image: th_P1030833.jpg]
8. Bonnet after
[Image: th_P1030837.jpg]
9. Shiney wing
[Image: th_P1030839.jpg]
10. Shiny'ish car
[Image: th_P1030840.jpg]
And couple of pictures at bottom of my field
11. Car at field
[Image: th_P1030847.jpg]
12. Car at field
[Image: th_P1030846.jpg]
S14 Zenki Build
Red inlet manifold Smile same as me
If weathers good going to mock up the FMIC over next couple of days.
FMIC parts to date:
- Single pass 2.25" FMIC 550x140x65
- (2) 90 degrees Mandrel Bent Pipes
- (2) 135 degrees Mandrel Bent Pipes
- (2) U Mandrel Bent Pipes
- (2) Straight Pipes
- (8) Straight Triple layers Silicone Couplers
- (16) Clamps
- (2) 90 degrees silicone coupler
- Inlet/Exhaust Gasket
- Xantia inlet manifold (red)
- Xantia FMIC piping: (Turbo pipe, inlet pipe with LDA feed, S bend)
S14 Zenki Build
Got a bit carried away with the pipes!
[Image: IMG_0918.jpg]
[Image: IMG_0921.jpg]
[Image: IMG_0927.jpg]
If all goes to plan should be on by end of next month.
S14 Zenki Build
Looks like you've got enough for 3 fmic systems there! haha Big Grin
Looks tidy dude , black ph1s are pure porn. a set of ph1/2 side skirts need adding to the wanted list Smile
@!Dan - Haha tell me about it, thought I'd get too many then not enough. Also not 100% sure what way I'm going to route it yet so at least having lots of pipes leaves my options open!
@puglove - Cheers mate, not sure if I can be arsed with side skirts etc. Quite happy just leaving the bodywork standard. Do the skirts really make that much difference? Tongue
S14 Zenki Build
Personally i always think the sill looks like its been bent with out them, just make the 306 look that little bit wider and meaner, also looks a bit low spec with out them i think
Stolen from mr lobb to give you an idea of the difference with skirts
[Image: DSC04482.jpg]
[Image: P1030699.jpg]
Yeah it looks good mate! Smile How much do skirts go for roughly?
S14 Zenki Build
Not a case of how much, it's how often!!!!
I've been looking for a set for bledy years that aren't fecked or £ra*e.99...
It just so happens i have a set of 3door astor grey ones you could have for 30 notes just throw a can of black over them Smile
Dammit!
Ruan Wrote:Dammit!
And I even offered you one of the 2 sets I have which you turned down so stop bloody complaining!
  Project T Phase 2.5 Diablo DTurbo... Kwik 90 75,794 24-02-2021, 11:51 PM
Last Post: stevieg
  Bianca phase 1 Dturbo Curt 76 48,737 15-09-2017, 12:27 PM
Last Post: partybish
  DTurbo Phase "X" Brookei 111 74,009 23-02-2016, 10:16 AM
Last Post: Brookei
