I'm back....GTIDI inside
I cut my 5 door slam panel to go over the rad. Loads of pics on here.
So managed to get a full day on the car yesterday
Front end off
[Image: 70549B87-7BA5-4C60-8444-12BD14A6B420_zpsifoerrhi.jpg]
[Image: 4FD626BF-64FE-4186-866A-30ACEDA8AC00_zpsxpm8jbsx.jpg]
Front mount on
[Image: C62B900E-E29C-4458-B63B-BFF896168A38_zps7wjmpqwn.jpg]
Little bastard spraying oil everywhere
[Image: 5EF6264B-4EAC-43F2-9894-12CAB755EDB4_zpsyrbjrqv5.jpg]
[Image: 8EDDDBCA-ADF3-474A-A41C-4D80B25D8356_zpsknv5f3nd.jpg]
Luckily had a new one lying round so fitted that
Also wired in a slimline fan to the original wiring so it comes on with AC button and fitted a new glow plug relay as it had packed up and some new solid linkages.
Stage 2 XUD Sedan
Looking good; hows it driving now; heaps better than before??
Going to betray my lack of 306 knowledge here, but why can you not go to the left of the rad with the return pipe from the IC rather than the convoluted route ?
What is in the way which isn't on the other side ?
The end tank of the rad prevents it from going that route.
That is a fair old route mate lol. Suppose its no worse than mine though
That's some pretty chronic extra piping there, got to be worth taking it through the washer bottle space and relocating that instead, surely.
Or up through slam panel and mod that. Less lag. Plus ure blocking half the engine cooling
Nice.motor though
Or run a ph2 rad with expansion tank seperate to get a bit more room down the side of the rad on the o/s
I suppose at least it's ally pipe on the run back so will give some extra cooling
Don't get him started on 'extra piping' Rolleyes
much pipe
Yay she's back Smile
[Image: siggy1.jpg]
Can I ask how you wired the fan to rhe AC button? Id like to do it on mine with a slimline
[Image: 20gh7o0.jpg]
It will be bloody tight getting the angle there but you can just get a pipe through between the expansion tank and the lower pipe inlet.
(15-05-2014, 07:52 PM)rd070707 Wrote: Can I ask how you wired the fan to rhe AC button? Id like to do it on mine with a slimline
You bridge two pins on an a/c plug which means when you press the ac button it turns the fans on. There's a thread about it
I figured out when I got the slam panel back on and everything urged in the I can easily route a pipe between the rad and slam panel. So I will be getting that sorted next for more direct piping Smile
Yes what SamBarker says, very easy job and most of the time the AC doesn't work in 306's anyway so we may as well put it to use.
Stage 2 XUD Sedan
Search Cullys helpful threads...re:AC button to fans
Good work there mate, top effort, does seem a long way mind!!
If you look at my thread, I cut back my slam panel and went over top too. My top of rad leabs back about 10mm too
(16-05-2014, 09:10 AM)Piggy Wrote: Search Cullys helpful threads...re:AC button to fans
Can't seem to find it, blame being on mobile though :p
Just out of intrest how do you go about insuring things like this? Also tax and logbook stuff? Might reshell mine into a phase 3 hdi at some point
(04-05-2014, 08:07 PM)Niall Wrote: That much Smile
Nice welding Smile
^^^^^ Nialls adapter.
