23-10-2013, 09:00 PM
Frosty's Ph1 Black D Turbo now with VNT
23-10-2013, 09:29 PM
Not really, you'll spend longer sorting your water feature
. . . . . Disclaimer....now it won't work for you the smokey old bus that sounds like a tractor...
27-10-2013, 07:30 PM
I put the other sunroof in the other day and sealed the frame when I fitted it. Hopefully it will sort my water problem but wont know till we get some more heavy rain which may be tonight if the forecast is correct.
I rolled the front arches the other night as well as the tyres scrubbed with the spacers fitted. Me, jimbo and craigus chipped in together and brought an archer roller and I must say I was pretty impressed with it I need to see about sorting the relay connector pretty soon as well as I cant use the heated rear screen at the moment. A few pics of the relay it melted And a pic of how it sits at the moment after fitting the different springs on the front and dropping the rear a little more. Think its lowered the front about 50mm which I think it sits pretty nice
29-10-2013, 01:17 PM
29-10-2013, 05:29 PM
that just a boot split or shaft gone??
any pics of the arches rolled close up? Wishes for more power...
29-10-2013, 05:48 PM
(29-10-2013, 05:23 PM)mr_fish Wrote: Too much boost ? Didn't think I would ever hear you say that lol (29-10-2013, 05:29 PM)Piggy Wrote: that just a boot split or shaft gone?? I reckon 1 of the balls has shoot out. Will have more of a look when I change it. I will try and get some pics when I change the drive shaft. Made a pretty good job!
29-10-2013, 05:55 PM
Like the look of the arch roller, good idea chipping in between a few of you.
29-10-2013, 06:02 PM
those arch rollers work brilliantly, I just used a dolly and a little bodyshop hammer from my mates bodyshop. worked fine.
29-10-2013, 07:11 PM
Smart!
29-10-2013, 07:57 PM
Oh no thats the long shaft aswell! Get your deep 11mm socket out!
29-10-2013, 08:31 PM
29-10-2013, 08:35 PM
Lucky you, my arms were cramping right up after lying under the car undoing those bastards!
29-10-2013, 09:38 PM
29-10-2013, 09:49 PM
Do you wona come and roll some rear arches for me
29-10-2013, 10:03 PM
it maybe the long shaft but if its just the half thats busted...just find a second hand half shaft n throw it in
29-10-2013, 10:29 PM
(29-10-2013, 09:49 PM)puglove Wrote: Do you wona come and roll some rear arches for me We could always rent it out to forum members Or come sw meet and use it then
30-10-2013, 06:46 AM
30-10-2013, 07:32 AM
30-10-2013, 08:28 AM
30-10-2013, 09:19 AM
30-10-2013, 10:34 AM
(30-10-2013, 08:28 AM)zx_volcane Wrote:(29-10-2013, 10:29 PM)Jimbo Wrote:(29-10-2013, 09:49 PM)puglove Wrote: Do you wona come and roll some rear arches for me To be honest by the time it's been send to you and you returned it would cost half of what a new 1 would cost to buy cuz it fairly heavy (30-10-2013, 09:19 AM)mr_fish Wrote:(27-10-2013, 07:30 PM)Frosty Wrote: I rolled the front arches the other night as well as the tyres scrubbed with the spacers fitted. Me, jimbo and craigus chipped in together and brought an archer roller and I must say I was pretty impressed with it I'm sure we can sort something out for you mark!
02-11-2013, 07:34 PM
I got the drive shaft changed so that's all good and back being able to drive it. From looking at the old drive shaft it looks like 1 of the caps has come off and all the pins fired out which is why the boot has 2 splits in it.
Also got some xenon bulbs fitted for my dip beam. There not a massive a mount better than the osram night breaker bulbs I had fitted but the blue ness makes them look a lot better. Also fitted some LED side light bulbs
07-11-2013, 07:46 PM
07-11-2013, 11:00 PM
(This post was last modified: 07-11-2013, 11:01 PM by devils_fuel.)
Looks shite..
Looks.. the smokey old bus that sounds like a tractor...
07-11-2013, 11:10 PM
(07-11-2013, 07:46 PM)Frosty Wrote: Some pics of the xenons fitted I had the same problem from an ebay rh shaft i fitted, dropped one in from gsf and cured it
07-11-2013, 11:41 PM
(07-11-2013, 11:00 PM)devils_fuel Wrote: Looks shite.. Cheers (07-11-2013, 11:10 PM)306Dan Wrote:(07-11-2013, 07:46 PM)Frosty Wrote: Some pics of the xenons fitted What noise did your make? The noise it makes is hard to explain but when it does it, it sounds really bad. Will try a 2nd hand 1 I have got and go from there. It drives fine though
10-11-2013, 12:07 AM
Had look into the noise I got when I pull away. I changed the driveshaft for a 2nd hand 1 and it is still there and then I checked the cam belt side mount which I found to not be tight so I tighten that up and the noise is still there. I would describe the noise as a harsh squeak and it seems to do it more in reverse. I'm wondering if its the clutch. I duno if anyone else has had any issues with a CG paddle clutch?
Frosty's astor GTi6 | Frosty | 20 | 8,401 |
26-07-2018, 05:12 PM Last Post: Frosty |
Black Ph1 D-Turbo project (black betty) | doogle-d turbo | 25 | 10,375 |
16-08-2017, 06:04 AM Last Post: doogle-d turbo |
Frosty's S16 6 speed | Frosty | 244 | 100,053 |
04-09-2014, 09:40 AM Last Post: Frosty |
