31-08-2013, 08:39 PM
Ill just wack fone on charge give me ten mins
![[Image: av5ym8.jpg]](http://i59.tinypic.com/av5ym8.jpg)
Frosty's Ph1 Black D Turbo now with VNT
31-08-2013, 09:24 PM
(31-08-2013, 08:12 PM)Frosty Wrote:(31-08-2013, 08:08 AM)karl1989 Wrote: Team black ph1. Looking good mate liking the cooler Dam right ![]()
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
01-09-2013, 09:50 PM
So the car is back on the road as of today. Done about 60 miles in it with no problem apart from it having a funny 5 minutes at the fuel station and not starting but it seems fine now. I have enjoyed every mile so far and it makes me realise how much I have missed this car. Will get some pics soon
01-09-2013, 09:52 PM
Yeah had a drive earlier epic turbo epicly quick spooling time. Once shes run in up the fuel/boost reckon u should see fairlt good power from it
02-09-2013, 10:25 PM
03-09-2013, 06:48 AM
not sure about the wheels. not sure they suit a ph1 so well.
but looks tidy how is it apart from the rubbing?? Wishes for more power...
03-09-2013, 06:54 AM
My mate 12mm spacers on the front and it was perfect dude give them a try?
03-09-2013, 07:14 AM
(03-09-2013, 06:54 AM)sam Wrote: My mate 12mm spacers on the front and it was perfect dude give them a try? how would front spacers stop a rear tyre rubbing?! ![]() Wishes for more power...
03-09-2013, 07:27 AM
(03-09-2013, 06:48 AM)Piggy Wrote: not sure about the wheels. not sure they suit a ph1 so well. I think the wheels finish the car off really well tbh. It's all be ok so far and I've done over 100 miles ![]() (03-09-2013, 06:18 AM)Jimbo Wrote: Sell me the challengers Nope
03-09-2013, 12:17 PM
06-09-2013, 08:08 PM
I seem to have sorted the rear tyre rubbing problem out. Put some 15mm spacers on instead of the 20mm 1s I had on the back and a bit more arch work with a hammer
![]() Going up to Trax on Sunday so the car will get a good run in, hopefully will be problem free A few more pics ![]() ![]() ![]() ![]() And a pic of inside at night. It is pretty bright ![]()
06-09-2013, 08:20 PM
Im warming to the wheels...its not the wheels, I think its the colour Im not sure on...
but still looks tidy as!! what gauges you running, egt, oil temp/pressure and boost?? did you have any issues with the stereo wiring reaching Wishes for more power...
06-09-2013, 08:30 PM
(06-09-2013, 08:20 PM)Piggy Wrote: Im warming to the wheels...its not the wheels, I think its the colour Im not sure on... With the wheels I was going to put them on just as silver but after seeing a few 306s with white wheels I felt it had to be done. Yeah for the gauges I got boost in the pod and EGT, oil temp and pressure in the centre. As for the wiring for the stereo I found it all reached pretty easy really.
06-09-2013, 08:40 PM
cool.
got wiring to do in mine tomorrow and wondered if it needed extending...ta ![]() Wishes for more power...
08-09-2013, 08:54 PM
09-09-2013, 09:17 PM
09-09-2013, 09:19 PM
looks good on the road!
mbc looks so far out it will fall out! Wishes for more power...
09-09-2013, 09:24 PM
10-09-2013, 06:09 AM
11-09-2013, 09:33 PM
I decided to gov mod the pump tonight after work. I had never done 1 before or had taken a pump apart so it was a good learning curve for me. As usual I got stressed out and felt like giving up but I got it done ok in the end with following Dan's guide on here and a few phone calls to Jimbo. Just now need to set the pump up again though I defo can fell a difference with it now fitted.
I do seem to have a bit of a problem with it holding boost though. It will reach peak boost, just over 20psi at the moment and then it will drop off straight away down to about 15psi. It only seems to have started since I fitted the MBC. Anyone help me out with this?
sounds like mbc is sticking or not set quite right. what turbo and mbc is it?
how have you got your turbo actuator set? Wishes for more power...
11-09-2013, 09:51 PM
The turbo is a K03 off an Iveco
The MBC is this 1 off ebay http://www.ebay.co.uk/itm/320679007155?s...1497.l2649 I got the turbo actuator on about full adjustment as that's the only way I could get it to fit
11-09-2013, 09:52 PM
that maybe your issue....the actuator being on full pressure
11-09-2013, 09:55 PM
12-09-2013, 07:13 AM
Frosty's astor GTi6 | Frosty | 20 | 9,759 |
26-07-2018, 05:12 PM Last Post: Frosty |
Black Ph1 D-Turbo project (black betty) | doogle-d turbo | 25 | 11,302 |
16-08-2017, 06:04 AM Last Post: doogle-d turbo |
Frosty's S16 6 speed | Frosty | 244 | 111,006 |
04-09-2014, 09:40 AM Last Post: Frosty |
