front strut brace fitting
Just a quick question about fitting the front strut brace, is it just as simple as removing the 3 bolts from the top of the strut and then bolting down the strut brace. I have got new longer bolts for it. I am just wondering if when i undo the 3 bolts on the top of the strut is anything likely to move or will it be ok.
Thanks Titch
As long as you don't push the car and its level it will be fine.
yeah and dont jack it up!!
Ive fitted an upper strut brace twice. It will undoubtedly move! Leave the car on the ground and undo the top mount bolts. However if it does move even by a few mm you will have to jack the car up to take the weight off the strut to then realign it!
You could also screw a bit of threaded bar into one or two of the holes to keep it in place.
Never had an issue fitting either of mine Smile
Flat ground and do not move the car an inch and all will be well Big Grin
[Image: siggy1.jpg]
Cheers Fellas, did it this morning, had the car nice and level on the drive, chocked both front wheel so nothing would move and all was good took about 10 mins..
[Image: aee8e327-e94e-4eb3-8f34-c22c4f896e0a_zps2ea70483.jpg]
[Image: 7b0e8f44-d716-4319-8ce8-1bb327fac3f3_zpsd098963f.jpg]
  fitting a front suspension ball joint impotentials 3 3,821 29-10-2016, 05:46 PM
Last Post: Poodle
  FRONT STRUT TOP MOUNT BEARING procta 1 3,447 27-02-2016, 07:15 PM
Last Post: welshpug
  Vibration issues after strut brace installation S16 14 6,874 16-12-2014, 02:11 PM
Last Post: S16
