so you making it so it doesnt come out?!
as...doesnt open?!
as...doesnt open?!
White phase 1, now with added truck turbo and massive head gasket failure
as...doesnt open?! Wishes for more power...
23-02-2013, 05:31 PM
(This post was last modified: 23-02-2013, 05:33 PM by ozonehostile.)
(23-02-2013, 05:30 PM)Piggy1987 Wrote: so you making it so it doesnt come out?! yeah, i never use the sunroof anyway, its easier to bond in apiece of lexan and paint it white that it is to reshell into a non sunroof shell also saves a bit of weight, have you ever lifted a full sunroof cartridge? not the lightest things in the world
25-02-2013, 05:25 PM
ok then, so a few people have asked me how long it takes to build a truck turbo 306, heres what i wrote down during the build, bearing in mind this was all done during evenings and weekends after work
![]() Bought a Bianca xtdt that had been off the road for a while under a tree, it was green, so the job list started with clean,T-cut and polish entire car - 10 hours repair ignition wiring due to non starting - 2 hours repair drivers door loom - 3 hours fit new window motors in all doors - 1.5 hours sand and spray sideskirts - 3 hours fit sideskirts - 2 hours remove and spray mirrors - 1 hour fit laguna splitter and refit bumper - 1.5 hours repair dents and scratches - 6 hours phase 3 headlights - 2 hours new cv joints and boots - 3 hours now for the good bits: turbo fitment and manifold fabrication - 15 hours remove turbo and refit (many times) - 8 hours total fit and refit downpipe - 2 hours relocate brake lines due to turbo fitment - 0.5 hours relocate battery top boot - 4 hours weld in battery box to boot floor - 5 hours relocate water hoses - 1 hour oil lines for turbo - 1.5 hours replace leaking oil returns - 1 hour fabricate cold air feed - 2 hours relocate wiper hoses and modify bonnet - 1 hour heat wrap exhaust manifolds and downpipe - 2 hours coolant and oil change - 1.5 hours refit interior - 2 hours adjust clutch cable as rubbing on driveshaft - 2 hours trim wheel arch liners - 1 hour 4 wheel tracking - 1 hour suspension height adjustment - 2 hours fit exhaust- 2 hours and finally, tax, mot and clean off oily handprints- 3 hours thats most of the important bits done, there would be several more hours of swearing, threatening to scrap it, cups of coffee, more swearing and angle grinding on top of that there you have it, how long it roughly takes to build my car ![]()
25-02-2013, 09:04 PM
I thought about some 4mm lexan and just bonding it in bit of universal edging round the outside!! Looks oem
27-02-2013, 10:35 PM
Been waiting for some bucket seats for the last few months and now 4 sets come along at once! just got to choose now, best choice is looking like a pair of carbon kevlar recaros
![]() also managed a couple of layers of base coat on the morettes during coffee breaks at work. just need to start my new job then i think itl be time to order some forged shinies
28-02-2013, 10:48 PM
Starting to get there, still having to wait hours between coats due to freezing temperatures, should be finished by now!
02-03-2013, 12:16 AM
(01-03-2013, 09:30 AM)306GT30 Wrote: Use the misses hairdryer thatll speed things up im banned from using that after "i broke it" using it for heatshrink haha
02-03-2013, 03:28 PM
finally managed to get a coat of gloss on while the weathers nice which i was pleased about:
![]() and then after a trip to see sam last night, got new shoes on, another set of pro race 1.2's but 16" ![]() already looks better but could maybe do with coming lower by about 5-10mm perhaps ![]()
02-03-2013, 03:43 PM
yours seems to sit at the same level as mine, defiantly needs to go lower at the front.
02-03-2013, 03:45 PM
(02-03-2013, 03:43 PM)Ricky Wrote: yours seems to sit at the same level as mine, defiantly needs to go lower at the front. yeah i think il start looking for the C spanner then haha. also got some solid beam mounts from sam that will be going on with the new beam and brakes. should be nice and low then ![]()
02-03-2013, 07:38 PM
looking good mate.
I wouldn't ever bother painting that bonnet, I kinda like it ![]()
02-03-2013, 07:48 PM
(02-03-2013, 07:38 PM)Luhoer Wrote: looking good mate. Haha, I get very mixed opinions from people on the bonnet, il take the stickers off once I fix the heatgun as that's my biggest annoyance about It other than it rattling all the time. But still, staying yellow for now as I would rather spend my money on making it go faster :p
10-03-2013, 03:47 PM
Very nice! Now spray the bonnet
![]() Welding and fabrication projects undertaken, contact me for more information.
10-03-2013, 03:51 PM
Looks awesome man!
I actually like the yellow bonnet :/
10-03-2013, 04:35 PM
Is it me or dont the hocky stick bits not quite reach the wings, looks really good tho!
10-03-2013, 04:48 PM
(10-03-2013, 04:35 PM)Chris_90 Wrote: Is it me or dont the hocky stick bits not quite reach the wings, looks really good tho! Ah, yeah its an issue I found when they were on, basically the donar car for the lights had a dimma bodykit, wide arches start at the indicator so the previous owner has trimmed the hockey sticks to compensate. Very annoying but Il think of something to fill the gap ![]() Was a bit unsure on morettes but soon as I put the first one in I loved the look. Also notice the gap between light and grill where I trimmed It to fit the crystals
10-03-2013, 05:21 PM
Looking good!
10-03-2013, 08:04 PM
the morettes look awesome!
btw are the morettes H4 or why can you just use the inner hole as a cold air intake?
10-03-2013, 08:35 PM
The outer lamp is h4 yeah, the inner lamps on morettes are just extra driving lamps.
When I find some crystal inner lenses I might put them back but I also kinda like the look of the air feed trumpets ![]()
10-03-2013, 09:21 PM
oh okay.. I hate H4s but the look of the morettes makes up for it.
you can use one lamp and the other as cold air feed, seen that on here somewhere, looks awesome
11-03-2013, 09:26 AM
(10-03-2013, 09:21 PM)Luhoer Wrote: oh okay.. I hate H4s but the look of the morettes makes up for it. I'm not the bipggest fan of h4 bulbs either but morettes are worth it, half the weight of crystals too ![]() Might be changing the front bumper for a phase 1 sports so could have spotlights in that to compensate for h4s
11-03-2013, 10:16 AM
(10-03-2013, 04:48 PM)ozonehostile Wrote:(10-03-2013, 04:35 PM)Chris_90 Wrote: Is it me or dont the hocky stick bits not quite reach the wings, looks really good tho! Just get some hocky sticks and cut them up and glue the bit on ![]()
11-03-2013, 05:31 PM
it will probably end up something like hacking up bits of hockey sticks haha
'09 Mercedes E320cdi wagon '99 306 gti6 |
Project Truck Turbo MkII, gathering dust | ozonehostile | 418 | 212,692 |
29-08-2019, 09:51 PM Last Post: Dturboleeds |
Bianca White Phase 2 Gti6 Track & Fast Road Car | Chr1sch | 62 | 22,018 |
22-02-2016, 01:54 PM Last Post: Chr1sch |
Mark's White Phase 1 XUD Project | MarkHam | 13 | 5,570 |
11-03-2015, 02:10 PM Last Post: anto |
