Threads: 28
Car Model/Spec: D turbo 97 Stripped Interier
hi, my heaters are really crap take ages get warm, with it getting cold now i need sort it out.
iv changed my thermostat and my engine gets upto temperature perefectly fine.
is my heater matrix clogged up?
i have bled it by the bleed screw near where the thermostat is located, im thinking i have missed one for the heater matrix or somthing?
Threads: 141
35
sounds like it could be a clogged heater matrix. easiest way to check is to follow the pipes from the engine into the matrix, check if both sides are hot. if it turns out that one side is hot and the other cold, you could try disconnecting the hoses where they go into the bulkhead and switching them round the other way and running the engine at about 2k rpm for 5 minutes, this is usually enough to clear out a small blockage as the reverse flow dislodges some build up. make sure you change the hoses back the right way around after and keep the coolant level topped up while bleeding any air out of the system.
The hoses can be a bit of a bastard to get off as they have those retainer clip things holding them on, I found a pair of needlenose molegrips and a lever bar very useful to get them off.
Hope this helps
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
Given 1 thank(s) in 1 post(s)
(30-11-2012, 12:39 AM)ozonehostile Wrote: sounds like it could be a clogged heater matrix. easiest way to check is to follow the pipes from the engine into the matrix, check if both sides are hot. if it turns out that one side is hot and the other cold, you could try disconnecting the hoses where they go into the bulkhead and switching them round the other way and running the engine at about 2k rpm for 5 minutes, this is usually enough to clear out a small blockage as the reverse flow dislodges some build up. make sure you change the hoses back the right way around after and keep the coolant level topped up while bleeding any air out of the system.
Hope this helps ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
Good tip
Threads: 28
Thanks that helps alot! Ill get back to you if I need anymore help
Threads: 226
24
Car Model/Spec: A3 TDi
Thats a clever idea! I just unplugged mine and stuck a hose in there and tried but it didnt work very well
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
I stuck a hose in mine and the water blasted out the other end so I assumed it was fine. I was wrong though it was incredibly blocked up, the water had just gone through one section of it. So don't just assume its ok if water passes through it.
Threads: 28
what can you do to unblock it then?
Threads: 226
24
(30-11-2012, 09:54 PM)therefused Wrote: what can you do to unblock it then?
Not alot. Its generally a put up with being cold (like me) or replace it.
Threads: 141
35
I would just buy a new matrix if Its completly blocked, only like 20 quid for a new one. I just reversed the flow on mine to try get enough heat to demist the screen, it worked to an extent and I guess it would be enough to clear a small blockage though
Threads: 115
I've tried thoroughly flushing the matrix both ways and until it is clear and the heaters still only get lukewarm. I think the answer is to throw caution to the wind and rip the dash out to change the matrix.
Threads: 226
24
(30-11-2012, 11:57 PM)ozonehostile Wrote: I would just buy a new matrix if Its completly blocked, only like 20 quid for a new one. I just reversed the flow on mine to try get enough heat to demist the screen, it worked to an extent and I guess it would be enough to clear a small blockage though
Thats the easy bit, its annoying that they're cheap to buy but then a farce to change!
Threads: 141
35
(01-12-2012, 01:57 PM)Tom Wrote: (30-11-2012, 11:57 PM)ozonehostile Wrote: I would just buy a new matrix if Its completly blocked, only like 20 quid for a new one. I just reversed the flow on mine to try get enough heat to demist the screen, it worked to an extent and I guess it would be enough to clear a small blockage though
true, but you forget all about how much of a hassle it was changing it once its working again. Il be changing the heater matrix in my 405 next week, driving back from london only blowing freezing cold air was not pleasant, genuinly think i have frostbite now lol
Threads: 226
24
Im not suprised! I get not cold air out of mine but i wouldnt call it warm haha!
