Help with heaters
I replaced one of my coolant pipes at the weekend and in the end I changed all the coolant. Put the car back together fine and with no leaking coolant point so I'm happy there and I bled the coolant system fine at the two bleed points. Got in the car early this morning and I could here it blowing but when I change the blower speed I can only feel it very very slightly. The blower motor seems fine?
Any ideas people?
That's odd, the blower speed isn't affected by the coolant. Have you checked it's not being blocked by anything?
Stage 2 XUD Sedan
Yeah it all looks fine to me :/ I'm really stumped here
Resistor? Or vent position flaps not moving properly?
An nothing to do with the flaps as when I change to windscreen or feet there is still nothing there.
Any ideas?
Might just be coincedental mate. Take the motor out and clean it up and give it some wd40. Might help free it up a bot
Yeah Id say you have an issue with the motor. Get it out. Clean it
Yeh check the motor.
Fixed Smile was nothing to do with the blower motor it was the little flap which allows the air into the blower motor.
(28-01-2013, 01:00 PM)David Wrote: An nothing to do with the flaps
riiiiiiiggggghhhhhhhttttttt Wink
Ooooops Wink
  heaters never get hot when moving LukeC88 9 5,488 27-01-2013, 02:29 AM
Last Post: samass
  heaters therefused 12 8,415 01-12-2012, 11:35 PM
Last Post: Tom
  Anyone have working heaters? Parksy87 10 5,592 10-10-2012, 12:35 PM
Last Post: Kwik
