Threads: 94
7
Car Model/Spec: 205 coming soon
If your wondering about the brembos you can get them behind cyclones using 20mm spacers I believe, not 100% on weather there just a case of bolt on but you will need new lines for them I'd go with braided
Official Team Go-NAD fan club
Threads: 141
35
(11-11-2012, 11:04 PM)the milkman Wrote: If your wondering about the brembos you can get them behind cyclones using 20mm spacers I believe, not 100% on weather there just a case of bolt on but you will need new lines for them I'd go with braided
nice to know that you can get them behind 15's, il be after some 16" team dynamics pro race 1.2 for when i actually do the conversion, im on 15" tds at the moment and they look good, just think going up an inch would fill the arches alot better and i could get some monster discs under there to match 4 pot calipers
Threads: 82
14
Car Model/Spec: P0XY Ph2 Dtub 5dr
(11-11-2012, 09:07 PM)ozonehostile Wrote: (11-11-2012, 09:01 PM)ash240970 Wrote: And if you ever get fed up of the 1.9 engine I have a 2.1 sat in my parts store(Malvern) I don't think I'll ever get round to using - be rude not to once you've got the bigger brakes on lol
Ooh a 2.1, now theres an Idea! You got any other nice parts you wouldnt miss?
Didn't say I won't miss it - just said I don't think I'll ever getting round to using it - the right amount of beer tokens may make me miss it a lot less though :whistling:
Only other things in there at the moment is a set of Ariannes but they'll be getting refurbed and painted eventually, 3 alpine V12 amps 3 other cheapo amps, a pair of focal 5' component speakers a powerflex lower engine mount and that's about it - well you did ask, lol
Threads: 17
Car Model/Spec: 306 Sedan PH1 XUD7TE Dturbo
Any power aproximation? Running with stock internals?
Threads: 141
35
(12-11-2012, 05:44 AM)SonnyRoby Wrote: Any power aproximation? Running with stock internals?
Not really sure what to expect power wise, but judging from the way it pulls through the gears id guess about 180ish bh, maybe more.
wheelspin in 1st, 2nd and 3rd sort of indicates that its got some serious grunt
Threads: 124
26
Car Model/Spec: Megane DCiR
Very interesting this, especially running stock pump, guessing its been gov modded, but nothing else other than a tune, thats all ive had done so far and managed good figuires on a wayy smaller turbo than yours. would love to see power this beast makes
never been a fan of turbos over the gearbox unless its a big fecker like this got me interested in this twin entry setup too.
would be interesting to see what this would be like with bigger pump.
Im contemplating a new build which has been done but never completed and run, 2.1 crank in a 1.9 block for more torque
CJ
Threads: 90
12-11-2012, 10:23 AM
(This post was last modified: 12-11-2012, 10:26 AM by darrenjlobb.)
(12-11-2012, 09:27 AM)CJ_Derv Wrote: Very interesting this, especially running stock pump, guessing its been gov modded, but nothing else other than a tune, thats all ive had done so far and managed good figuires on a wayy smaller turbo than yours. would love to see power this beast makes
CJ
In other words finishing off JP's build that he gave up on lol?
For measureing the belt, the way ive always done it (and believe me ive done it alot of times with all my different supercharger arrangements!) is ive got an old belt (longish one) thats cut in half, then you just wrap it aroundthe pulleys how you want, overlap them, and draw across the belt where they meet, then remove it again, lay it on the ground flat, and measure it on the floor, then just buy a gates belt 6pkxxx where xxx is the length in mm that you just measured....works everytime! You need to be more accurate than you think, the tensioner will only take up 5-10mm tops, anything more than that and itl be no good!
Threads: 124
26
[/quote]
Yeah pretty much Darren, i just havent had the funds for the rods, ive got the crank etc just costs a fortune for custom rods but would be very interesting to see what power it would make as my local derv specialist told me to do this years ago as its all about the torque
And got to say thats a BELTIN idea for measuring a belt
CJ
Threads: 541
124
Hi mate, I am selling a set of 406 brembos with the Tarox G88 discs that are supposed to stop them squealing. Only done a few thousand miles on the pads and discs cos i wrote the car off.
Also you say its a twin entry turbo, I take it you mean a twin scroll?
Have you considered a quick spool valve as then youd have boost much lower in the rev range but loose nothing top end (ive spent a fair bit of time looking at twin scroll set ups)
Basically the valve sits between turbo and manifold and at low boost levels only lets the exhaust in one scroll of the turbo then its opperated by a boost actuator and opens a flap to let exhaust gas into both scrolls at high boost levels. Theyer not commonly used in this country but are over the pond, theyer about £150 IIRC but i reckon you could make one for £30
Threads: 141
35
12-11-2012, 01:20 PM
(This post was last modified: 12-11-2012, 01:23 PM by ozonehostile.)
(12-11-2012, 11:47 AM)Dum-Dum Wrote: Hi mate, I am selling a set of 406 brembos with the Tarox G88 discs that are supposed to stop them squealing. Only done a few thousand miles on the pads and discs cos i wrote the car off.
how much do you want for those calipers and discs mate? Il have a look into those valves, sounds like an interesting development
CJ
Is like to see if that would work, would be awesome if it does
Threads: 3
Car Model/Spec: Need ZX dervv :-(
Oh my! now this is a build i will be keeping an eye on!
Really like the car tbh, much like my mates but with a awesome engine.... wish he put the XUD in his new one into the old more door!
Threads: 124
26
I know imagine the torque that it could well produce along with this that Dum Dum has just got me very interested in Twin scroll setup .................google time haha
Looks a evil motor too with front mount just slapped on reminds me of my blaze no descreteness just all in your face just like your turbo
Threads: 36
18
Car Model/Spec: DT
Really really love this! Please go get it on the rollers !
On the 306 waiting list.
Threads: 141
35
12-11-2012, 03:06 PM
(This post was last modified: 12-11-2012, 03:12 PM by ozonehostile.)
(12-11-2012, 01:42 PM)PUGMON Wrote: Oh my! now this is a build i will be keeping an eye on!
Glad you appreciate it, more doors, more whores haha
(12-11-2012, 01:53 PM)CJ_Derv Wrote: I know imagine the torque that it could well produce along with this that Dum Dum has just got me very interested in Twin scroll setup .................google time haha
Plus Its very hard to be discreet with a 4inch straight thru 'zorst and turbo chatter, certainly turns heads driving through town haha
That boost valve would defy the point of building a properly matched manifold, could improve your current arrangement though.
Threads: 124
26
We dont need Discreet with a blower like that mines discreet in the way of intercooler tucked behind bumper and standard looking roll tip stainless zorst but only 2.75" tip BUT.... sounds like a jet lol
would like to see this on dyno and hear it also
Threads: 44
7
Car Model/Spec: Miami 205 TD
Let me know when you get in on a dyno, could bring mine along too
Threads: 130
82
Car Model/Spec: 106 GO-NAD
nice, deffo interested to see what sort of power this makes!
Threads: 141
35
(12-11-2012, 04:48 PM)Pugmarshall Wrote: Let me know when you get in on a dyno, could bring mine along too
I was thinking of booking a dyno run at Saxon motorsport in hereford or dng tuning in Worcester as I might be able to get a discount with my mini club membership haha. Anyone else In the 3 counties be interested in a dyno run?
Threads: 82
14
Pugmarshall and I know a place that does dyno runs that could be incorporated into the midlands meet (separate thread) but I already went on the rollers earlier in the year. Still I'd turn up wherever just for the meet up.
Threads: 141
35
(12-11-2012, 05:09 PM)ash240970 Wrote: Pugmarshall and I know a place that does dyno runs that could be incorporated into the midlands meet (separate thread) but I already went on the rollers earlier in the year. Still I'd turn up wherever just for the meet up.
Sounds like a plan, I just need to get It Insured again and get my new boost pipes fitted and Itl be ready for action
Threads: 44
Car Model/Spec: 306 d turbo
can you post a video of it launching of the stand still ? bet it goes like f*ck,lol.
Threads: 141
35
(12-11-2012, 05:36 PM)bayley Wrote: can you post a video of it launching of the stand still ? bet it goes like f*ck,lol.
il charge the camera for next time i go down the lockup for ya
Threads: 127
33
Car Model/Spec: ZX Volcane TD
+1
Threads: 44
(12-11-2012, 05:40 PM)ozonehostile Wrote: (12-11-2012, 05:36 PM)bayley Wrote: can you post a video of it launching of the stand still ? bet it goes like f*ck,lol.
il charge the camera for next time i go down the lockup for ya ideal mate i will keep an eye on this thread,look's a beast
Threads: 141
35
i decided to do a tiny little video of the 306 running, forgive the shit quality, i filmed it on my phone which just couldnt handle how loud it is, but anyway its better than nothing until i get around to making a proper vidio of it.
Threads: 44
sounds like its got a nice deep roar...as you said vid quality a bit shite,lol.
Threads: 141
35
(12-11-2012, 09:44 PM)bayley Wrote: sounds like its got a nice deep roar...as you said vid quality a bit shite,lol.
its certainly a roar, easily drowns out a scooby impreza (i know from experiance haha)
but yes apologies for low quality, il dig out the hd video cam this week
Threads: 102
9
whats the boost like on this?
Threads: 141
35
(12-11-2012, 10:04 PM)procta Wrote: whats the boost like on this?
only running at 1.8 bar currently, just until the engines been run in a little bit with this setup
