Threads: 25
my coolant has started dropping in the past few weeks.
there are no leaks visible anywhere.
loses about 1 litre every 120 miles
what could be the cause of this and what can be tried to stop the leak?k seal?
didnt lose one drop of water up until last few weeks
Threads: 28
Car Model/Spec: Phase 4 Silver HDi Estate
split pipe/join busted rad?
Threads: 25
no split pipes anywhere-recently had a new rad
Is it worth trying k seal?
Threads: 124
26
Car Model/Spec: Megane DCiR
Pressure test system check metal pipe running around back of block and little rubber one above gearbox this connects too metal one can pinhole and be unnoticed as heat from turbo dries it up
Threads: 19
Car Model/Spec: Ph1 D-turbo(on going project)
you got a wet passenger footwell? possible heater matrix or headgasket.
or pipe behind engine, metal one on mine had a pinhole in it
Threads: 25
No wet footwells.
where does the pipe on the back of the block go to?
Threads: 51
Car Model/Spec: '96 ph1 DTurbo 'S'
my bianca was loosing water from behind injector 1, theres a small water take off there
Threads: 28
k seal is the worst thing for the xud's. clogs up way more then the leak. steer clear of using any leak fixer on these cooling systems
Threads: 202
58
put a chocolate egg in the rad?
