D turbo losing water
my coolant has started dropping in the past few weeks.
there are no leaks visible anywhere.
loses about 1 litre every 120 miles
what could be the cause of this and what can be tried to stop the leak?k seal?
didnt lose one drop of water up until last few weeks Sad
possible head gasket?
split pipe/join busted rad?
no split pipes anywhere-recently had a new rad
Is it worth trying k seal?
(02-09-2012, 07:19 PM)306 d turbo Wrote: no split pipes anywhere-recently had a new rad
Not if it isnt leaking lol
Pressure test system check metal pipe running around back of block and little rubber one above gearbox this connects too metal one can pinhole and be unnoticed as heat from turbo dries it up
[Image: J5hxCcC.jpg]
you got a wet passenger footwell? possible heater matrix or headgasket.
or pipe behind engine, metal one on mine had a pinhole in it
No wet footwells.
where does the pipe on the back of the block go to?
(02-09-2012, 10:04 PM)306 d turbo Wrote: No wet footwells.
goes from the plastic block which iirc bolts onto block where water pump is and then to the thermostat housing mines a 1 pipe some have 2 pipes
oh i think i may have a spare btw if you need it £10 posted bud
my bianca was loosing water from behind injector 1, theres a small water take off there
k seal is the worst thing for the xud's. clogs up way more then the leak. steer clear of using any leak fixer on these cooling systems
put a chocolate egg in the rad?
  Losing coolant Spoonaltap 8 2,783 19-03-2015, 04:36 PM
Last Post: Spoonaltap
  Losing the love Nathan1305 15 4,422 10-02-2015, 04:01 PM
Last Post: Nathan1305
  Turbo water cooling Jenkosowls 18 3,502 08-06-2012, 02:41 PM
Last Post: darrenjlobb
