Toms306s Project - Fodge!
Ruan Wrote:
c.a.r. Wrote:The hoses on your oil catch tank look restrictive?
Also, oil catch tanks are for high-revving engines which occasionally let a bit of oil through. How high does the diesel rev in this thing exactly?!
Finally, those shoulder pads might well be comfortable but they are not always safe in an accident, whilst also making your car look like a pensioner-mobile...
Turbocharged engines are terrible for chucking out shedloads of breather gasses - understandable as you have pressure on the piston rings for 99% of the time - on an NA you have a fair amount of time where they're not under pressure during induction, not to mention the compression ratio of a Diesel... You'll usually find that on a Turbocharged diesel engines, if you adjust ANY of the stock breather system, it'll end up just spewing oil breather gas from everywhere, popping up it's dipstick rather than catching any of it in the catch tank.
There was loads of oil in the bodged catch tank when I took it off though!? Wish id left it there now. :/
Right....so the turbos ready to come off now..........last part is the turbo oil feed that I can't seem to remove...any ideas how to get it off? A spanner won't fit between the two halfs of the turbo...so what am I supposed to do...? :?
[Image: turbooilfeed005.jpg]
[Image: turbooilfeed006.jpg]
[Image: %24(KGrHqRHJDcE63Z(lQ40BO0r7wqVv!~~60_35.JPG]
or even...
[Image: images?q=tbn:ANd9GcSq4q3RYJN5NGbCvsSxzrV...ZTPYYuTGI4]
A swan neck would probably be a good idea of Tom was some kind of magician, who could make it go through the solid oil line. Unfortunately, he's not lol
Scotts right lol....
Plus a swanneck or any normal size spanner is actually too long anyway, it hits the bulkhead. :problem:
After looking around I've found this (wrong engine but similar mani) - half a spanner, with the end cut out, and a bend welded in............surely that isn't what VW would use though lol!! Confusedhock:
http://www.myturbodiesel.com/1000q/a4/t ... engine.htm
Crowsfoot wrench or flared spanner mate. Think it's gonna be fun whichever way you go...
[Image: Sig500x130.png]
tom whats it connected to on the other end? as it mite be worth removing it from there and lifting it off with the turbo. make life a little easier.
Yeah I thought that too mate.....no chance though, it goes around coolant pipes and various wiring and stuff. :problem:
I would just cut it off if it was easy to replace lol.
Someone in chat earlier was saying about rule number 2...I think it's applicable here...if it can be removed, do it anyway. It'll make the job easier later on.
Case in point, remove shit from the front so you can follow the line around and remove it from the other end if you have to. It looks a bitch to get off, but worth doing no doubt.
Usually I'd agree, but I'm not removing half the cooling system just for an oil line lol....might just see if my grandad had any old spanners that I can cut up. I assume I could cut it with a hacksaw as I don't have anything bigger or electric lol.
Btw if you're changing the turbo, have you completely unbolted it so you can drop it down to the floor to make it easier to rotate and get to? If the feed is long enough, of course.
It won't come out underneath without removing driveshaft....f*cking awkward vws! So I've taken the inlet mani off to take it out the top hopefully. :think:
[attachment=0]
Scott Wrote:A swan neck would probably be a good idea of Tom was some kind of magician, who could make it go through the solid oil line. Unfortunately, he's not lol
okay then you picky bastard use one of these then!
[Image: Flexible_Flare_Nut_Off_Beam_75_degree.jpg]
or one of these...
[Image: sealey-s-spanner-set-5pc-metric.jpg]
You realise the bottom ones there are solid aswell Phil! Tongue
That top one would be ideal if it would fit though....bet they don't sell them in halfords though!
Eh you get the idea! Lol
Erm..........have I been a complete bellend? If I've read this right it says I don't need to undo the bottom nut at all to get the oil line out?? I don't want to break it so should it just pull out now I've removed that 'top' nut?? :?
http://forums.tdiclub.com/showpost.php? ... stcount=27
If I can get a quick reply that'd be good please....! Smile
Nevermind, I'm a dick.....it just pulled out with a hard pull. f*ck sake. :problem:
A push fit oil line? I don't like the idea of that...
THE_Liam Wrote:A push fit oil line? I don't like the idea of that...
No its compression fit, that big nut holds it tight. It didnt seem at all loose last night and I didnt want to break it so didnt pull too hard.....and assumed the smaller nut must have held it somehow....but it doesn't. Smile
lmao that is all
I was going to say this, but I thought you couldn't be THAT much of a pleb... Seems I underestimated you Tongue
Curt Wrote:I was going to say this, but I thought you couldn't be THAT much of a pleb... Seems I underestimated you Tongue
Oh I can be MUCH more of a pleb than that lol.... Tongue
Anyway....yeah it's f*cked. Tongue
[Image: Knackeredturbo037.jpg]
[Image: Knackeredturbo039.jpg]
[Image: Knackeredturbo038.jpg]
And this is where its sitting for now lol...
[Image: Knackeredturbo041.jpg]
can you not get a rebuild kit for it?
samass Wrote:can you not get a rebuild kit for it?
Tbh I don't think I have the pateice and certainly not the skill to do it myself after reading some garett refurb guides lol.
Also Ruan said that they can't be refurbed for some reason, not at any old garage anyway.
Just for a laugh I asked in VW the price of a new one.............£1126 lmao
jeeeeesus thats a lot!
samass Wrote:jeeeeesus thats a lot!
I know lol...... :problem:
Not sure what to do now tbh..........wonder how much its worth spares or repair, cos the body and interior are mint (just ask anyone thats seen it), its just the mechanical problems that let it down. Sad
or save up for a replacement turbo? theyre like 2-300 on the bay
  Toms306s "Bit Of A 'State" Toms306 227 160,744 12-11-2012, 10:29 PM
Last Post: Jonny81191
