Annnd we are back up and busy again! Payday was last week so ordered a few bits. Firstly, got a bargain Gates cam belt kit. Was on eBay for £70 or make an offer so i made him an offer of £50 and he took it Big Grin
Also got some purple (well in the photo it was purple but its more pink Sad ) hose for the map sensor, boost gauge and FPR and a nice big sheet of metal. Hopefully have the charger bracket mocked up this weekend and the engine timed up Smile
Oh and I've also ordered new shocks and springs as I'm really not getting on with the D2s. The car seems to handle worse and grip less with them no matter how i set them up but then I'm also turning into a old bastard and want it to be more comfortable lol.
Awaiting me when i got home was a massive parcel which contained this lot.
Bilstein B8 shocks and Eibach Pro springs to replace the D2 coil overs. This is the same setup i had before i bought the D2s and it way a much nicer ride.
Parts hoarding is going well. Room is starting to look like a bloody stock room but hopefully it will all be fitted in the coming weeks!
Ooh big pile of bits
My old D2's by any chance?
Well they weren't gonna be pellowe's lmao
True that, wounded were they went
(04-12-2013, 06:43 PM)sam Wrote: My old D2's by any chance?
Yes mate they are Smile
how easy are these to supercharge, can the stock engines take the charger as they are?
dude, head in the sand much?
http://www.lynxpowerengineering.co.uk/sc.aspx
(04-12-2013, 08:51 PM)welshpug Wrote: dude, head in the sand much?
i don't play with pugs so i haven't read up on what the crack is with these engines. welsh pug.
Everything is improved by supercharging
Tbh id of rather turbo charged it but i couldn't really afford the added cost. 220ish will be plenty enough for me!
(04-12-2013, 09:19 PM)Niall Wrote: Tbh id of rather turbo charged it but i couldn't really afford the added cost. 220ish will be plenty enough for me!
you wont be bored with that!
Niall, I think I've already asked you this. But have you already bought the OMEX? I was chatting to chip wizards today and he's just done the mapping for a 205 with exactly the same setup as you, but on stock management. Only change was change the map sensor to one which can read boost - the rest can be reconfigured in the stock ECU.
JP
JP
Yep Omex is already here. I did hear rumours that you could use the stock ECU with boost (not the cheating way like Lynx) But i couldn't find a definitive answer so just went for the Omex. Gives me more ability to play with it anyway once its all set up.
Edit: how much does Wayne charge for a mapping session or does he do it by the hour? Heard very good things so tempted to drive the car up NA on standard management then swap the loom and ECU over int he car park and let him work his magic.
Yep, you 100% can. You just need to know how to re-write some of the ECU to do it. It then behaves like a stock car, retains all OBD compliance for fault code reading, but yet reads boost properly and fuels accordingly. We've been working on the launch control on mine today, still on the stock ECU. It's a motorsport derived ECU anyway, which is pretty much identical to Magnetti Marelli's £7k full fat jobby (with a few less features).
You'd have to ring him and ask for a ballpark (07874328306).
His workshop isn't very far from mine at all really, given you are from a gazillion miles away... you'd be more than welcome to do it here and we could trailer it over...
JP
JP
(13-12-2013, 07:52 PM)jammapic Wrote: Yep, you 100% can. You just need to know how to re-write some of the ECU to do it. It then behaves like a stock car, retains all OBD compliance for fault code reading, but yet reads boost properly and fuels accordingly. We've been working on the launch control on mine today, still on the stock ECU. It's a motorsport derived ECU anyway, which is pretty much identical to Magnetti Marelli's £7k full fat jobby (with a few less features).
JP
Thats kind of you Smile
Ill see whats happening in a few months when the engine goes in. Tbh i would consider keeping the stock ECU but i like the idea of being able to play with the map my self which of course is easy with the Omex.
By the way, what colour was this 205 your on about? I know 3 people with them 2 of which currently have broken ECUs lol
No idea mate, sorry.
JP
(13-12-2013, 07:45 PM)Niall Wrote: Yep Omex is already here. I did hear rumours that you could use the stock ECU with boost (not the cheating way like Lynx) But i couldn't find a definitive answer so just went for the Omex. Gives me more ability to play with it anyway once its all set up.
Pretty sure Wayne made the maps for Lynx.
He did yes. He wrote all the software for the low boost and high boost setups.
He now does it a bit differently, and changes the ecu to allow it to see boost!
JP
JP
Correct he did but the way the Lynx kits are set up (except the super high boost) means the ECU does not see boost and thinks the engine is still N/A.
[/quote]
which it can deal with quite happy as the air volume supply with a charger is linear through the rev range unlike a turbo
Yep.
But the better way is measure boost pressure, due to the filling of the intercooler pipes etc before the "boost" actually hits the manifold - and when you come off the throttle.
There's basically a lag time in ECU response as the sensors are so far away from the manifold, and the otherside of a big charger...
JP
Charger bracket is all mocked up and ready to go! Unfortunately i can't weld it properly as our welder isn't man enough to weld 5mm steel properly so for now, its all been tacked together to make sure its all in the right place and then it will be welded properly one eve this week.
Hopefully get it welded up this week then next weekend i can get it fitted to the engine and go and get a belt then its all ready to drop into the car!
Have to say a massive thanks to Grant for his help with making this over the past few days as he pretty much did all of it for me whilst i stood back and watched lol
Nice one Grant Big Grin
Nice to see it taking shape. You got an intake mani sorted yet?
After typing that, a pic of it popped up. Neat little mani that. Nice colour scheme too.!
[Image: Sig3_zpscd005eb1.jpg]
Good work,
This is exactly the sort of project I dig, homemade, custom 1 off things Tongue
10 times more interesting than any lynx bought kit! Even if it isnt as good at first / takes time to get right, thats what the fun is all about!
(15-12-2013, 10:32 AM)darrenjlobb Wrote: Good work,
Couldn't have put it better myself.
Personally, I would find no fun out of buying everything and just bolting it on. This way, it takes 10-100x longer, but is a million times more interesting and rewarding.
Sorry for not reading the whole thing bit what are you doing regarding recirc valve/dump valve? Off the charger that is
You will also learn 100 times more shit doing it yourself...you learn nothing bolting stuff on except how to work a spanner, and you cant learn that properly either as everything just bolts together easily, no "bending this" "semi crossing that" "tweaking with a drill twisting around that" lol.
Also this will sound 100 times better than a centrifugal SC, whine ftw, i miss my dervs charger soooo bad!! You will never drive past a single person again taht dosnt turn there head and think either "WTF is in that car ", or more likely due to most peoples dumbness, "WTF is wrong with that car!!!!"
That gather looks hench! Good work!
  Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. Matt-Rallye 29 26,041 10-05-2017, 12:49 PM
  Matts £200 Cherry Rallye shell rebuild & tidy up project. Xsara goodies landed! Matt-Rallye 70 66,050 07-03-2017, 12:58 PM
Last Post: Matt-Rallye
  Moonstone GTi6 Track-Lite Project reese 28 26,514 29-01-2017, 09:34 AM
Last Post: reese
