Stanced XUD Estate (IT'S ALIVEEEEahahaha)
Me too, especially as Gav gave me the engine on the premise that it was a good working one. Will be absolutely furious if it turns out to be the HG.
Will try bleeding again and check the 'stat.
Just spoke to Gav, he's confident the HG is fine. Will try bleeding again tomorrow.
The good news though is that the engine fires over without priming the bulb now I have diesel in the tank, win. Glow plug relay has stopped making weird noises too, guess because the battery got a full charge lol
I do hope you get to the bottom of this mate! mine never gets warm either so I wouldn't worry about that, the pressurizing is more the problem, and yeah I'm pretty sure the oil pressure sensor is the one above the oil filter Smile I have a few at home if you want one sticking in the post Smile I would come and give you a hand but your a bit far away and I have enough problems of my own to sort in the next few weeks! lol
Team Orange Engine Bay
Sounds very head gasketty to me....
Do the heaters go red hot even though the radiator is cold, or does the rad get red hot and the heaters worryingly cold?
Didn't run it long enough Ruan, oil pressure and stop light worried me so turned it off.
Going to have another bash at bleeding again tonight. Have a feeling it's badly airlocked after the rear pipe split and was replaced, bled it lazily after that. Engine fires up fine and no condensation out the back, if coolant was pressurised it should be flooding the cylinders after being turned off but it's not.
Btw where are the bleed points? Found on on matrix, top of rad, lower t shaped hose but that's it, is there one on stat housing?
cwspellowe Wrote:Didn't run it long enough Ruan, oil pressure and stop light worried me so turned it off.
They are the only ones on mine,
I'd run the engine for 10mins or so because the oil pressure will drop a fair bit once it's heated up and the oil isn't so viscous.
On the 306 waiting list.
Doesn't necessarily have to flood the cylinders...
The head gasket on my car is beyond repair, it's absolutely shagged, orange engine bay and everything, bubbling and spurting coolant on idle - but it doesn't flood the cylinders once turned off even now...
Bleed points are on the line from behind the fuel filter/thermostat housing, should be next to the fuel filter. The other is on the heater matrix.
Bleed by opening the top one first, give yourself an orange 'tash and make sure that one has water spurting out, then open the other one and run up the engine, should splutter a bit of water, then go to a steady piss of it... Close it, leave it run until the radiator starts getting warm, keep topping up the coolant as it gets all the tiny bits of it out, especially when the thermostat opens, there's usually a big gurgle and it'll eat a load, then it's pretty much all done.
How long were you running the engine for with no coolant in?
Ruan, your engine bay looks like mine currently does I'm guessing then??
[Image: IMAG0033.jpg]
lmao
Dan, ran it for maybe a minute or two, didn't have enough derv as the tank was bone dry, got it
Fired and adjusted timing then switched off
Jesus christ, Mark!!!
That's actually worse than mine, good work!!!!
Ruan Wrote:Jesus christ, Mark!!!
Pretty epic isn't it! lmao I'm not sure but I think I might have HG issues ATM..........Hmm
I'd NEVER have guessed!!!
cwspellowe Wrote:Dan, ran it for maybe a minute or two, didn't have enough derv as the tank was bone dry, got it
Id be worried about running an xud with no coolant in for more than 20 seconds tbh, maybe thats just me being sceptical but I know they really dont like running with no water.....
The head would have been steaming by that point - over about 40 seconds, they get VERY hot.
...f*ck.
There was steam/smoke coming from the engine but assume that was all the spilled diesel from bleeding, was pretty much covered in it.
If it's hg I won't be making FCS. no ifs, no buts, no money. Game over.
hg only takes couple hours to take apart and put back, plus time to get head checked / done...you can still do it Smile
FFS, how much is a flight up to Scotland gonna cost me?
Bugger, cheapest with Easyjet is £100 return Sad
shame to hear about HG man but il look out for some xud engines in scrapys if im about them. had look on ebay hg sets are about 30-60 depending on set you get some with bolts i can come round give you a hand if you want. i can show you new car i got traded merc in for lol Smile
If it's definitely HG I can probably batter in and fix it but it's all money, this month was always going to be tight what with MOT, tax and insurance needed, factor in parts for HG and i'll literally have to sell stuff to get through the month.
Haven't had the heart to go out and bleed it tonight so another day of pondering ahead. Someone go confirm the damage for me?
Two weeks to French car show, no MOT and i'm getting the paint out.
This is going to be Top Gear-esque race to the finish line and is going to be either mighty or terrible...
Good luck mucka....! Smile
[Image: Sig3_zpscd005eb1.jpg]
Hows the engine fairing mate?
cwspellowe Wrote:Two weeks to French car show, no MOT and i'm getting the paint out.
lol Good luck mate, I currently have most of my engine bay out and plan on having the engine out by bedtime tonight if I can..........so I guess its going to be pot luck if one or either of us make it at this rate, we can have a convoy of success though if we are both there Big Grin
Paint....... You mad?! Recipe for disaster this close?!
An mark.... MTFU and get it done! I'm doing mine tomorrow lol
It's either paint or turn up with a roof covered in primer and filler. I'll take my chances. Going to use proper BC/CC though and get plenty of clear so I can get the machine polisher on it.
Engine is being looked at again tomorrow. Think I know the problem though. Heater matrix pipes are kinked so I have more hose to re-route them, the XUD9 has a port on the back of the head for coolant, the XU10 doesn't, it has two separate pipes for the matrix. Think by blocking the matrix pipe the head hasn't been getting coolant and the blockage pressurised it. Might just be me being hopeful but I don't think the HG has gone.
Decided i'm going to concentrate on getting it running tomorrow. As long as it runs, bodywork takes a back seat. Roof will be painted like so:
[Image: roof2.jpg]
[Image: roof1.jpg]
Might upset a couple if you but me and vinyl don't get on, and the original paint is buggered. Roof's all smoothed off though with a Buick style shark fin aerial at the rear of the car, hopefully be nice and tidy by the time it's done. Hopefully.
Ahhh fair enough, genuinely thought you were going a diff colour haha. Roof looks sweet like that Big Grin like very much!
Something different, saw a white Signum with gloss black top half and it looked mean, tried it with vinyl today and it ended badly so just going to paint it seen as the weather's nice and mild.
I think that looks great....! Really fresh and different. It will be a Marmite thing no doubt, but.... Me likey! :grin:
  rd's moonstone HDi Project - Now Stanced rd070707 99 51,687 02-05-2013, 11:05 AM
Last Post: rd070707
