10-04-2012, 09:11 PM
i have 20days to solve it before its hitting the garage.....306oc.co.uk get to work people with suggestions
haha cause im stumped
Electrical problem
10-04-2012, 09:50 PM
My bets on an earth fault
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
11-04-2012, 08:21 AM
Well I've looked and can't find a definite answer to all the earth points...anyone know so I check them over...I guess for the time being my car wont earn an extra mile or two whilst it's refusing to work
11-04-2012, 08:24 AM
the earth underneath the drivers footwell is a large earth, could be related - im useless with electrics, but know a few earth points.
check that one??
Phaes 1 GTI 6 - Onyx Black
11-04-2012, 08:38 AM
I'm just going to check all my earths. Hopefully it's something silly...just don't understand why I replace the part and refuses to work altogether,put the old one back in and don't work either so it's annoying lol
11-04-2012, 08:39 AM
ben87 Wrote:I'm just going to check all my earths. Hopefully it's something silly...just don't understand why I replace the part and refuses to work altogether,put the old one back in and don't work either so it's annoying lol may be worth then just whipping that out again, check the plug, pins, board etc... and work your way from the start again
11-04-2012, 11:33 AM
I think you must have knocked something when fitting the new unit. Isn't there an earth there?
11-04-2012, 01:04 PM
Other thing it could be is a f*cked box.
There is a little wheel In the gearbox that runs the sensor. I would start the car and turn the speed sensor and get someone to watch the speedo. If it works, could be new box time
11-04-2012, 01:30 PM
There is no way of turning that speed sensor it's covered in oil and a tubular shape so nothing will grab onto it. Well the gearbox currently on there is a 2nd hand on so guess another one will b needed soon. Calling Tom - can you do gearbox changes haha
11-04-2012, 09:59 PM
Just went to look on autodata and my car laptop is flat and I can't find the charger
![]() One under the dash on drivers side, one on top of the gearbox. Will more than likely be one of these two
11-04-2012, 10:10 PM
12-04-2012, 06:09 PM
Anyone got a pic of the earth location the the gearbox housing??? I appreciate all this help but got limited time to find problem
12-04-2012, 06:14 PM
ben87 Wrote:Anyone got a pic of the earth location the the gearbox housing??? I appreciate all this help but got limited time to find problem It's just behind the filler point. Just follow the lead from the battery neg. it's easy.
12-04-2012, 06:15 PM
so the lead will go down to the earth on gearbox? cheers will go find it now.hopefully thats simply out of position
12-04-2012, 07:04 PM
Checked all earths and nothing is loose at all
Could it really be an internal gearbox problem??
12-04-2012, 07:11 PM
If I was you, find out what earth wire is on the speedo plug and check the continuity to the battery. Could be a smaller broken wire.
Electrical fault finding is a pig ![]() I hope for your sake it isn't a internal gearbox issue!
12-04-2012, 07:17 PM
Will dig out servicebox and inspect a few things tonight I think
balls just as the car was comin up trumps
12-04-2012, 07:19 PM
It ain't a gearbox problem, its an earth problem from the back of the sensor
12-04-2012, 07:54 PM
No you checked the right part. The other circled one is nothing to do with speedo. Part 2 on the right hand drawing is only plastic. Could of been damaged? I hope not but think before you check that out, check all the wiring out.
12-04-2012, 08:01 PM
Good. Need to check wiring then failing that, part 2 I reckon.
12-04-2012, 08:03 PM
It was an intermittent fault, which screams electrical fault to me, as a mechanical part will either be fine and work, or be f*cked and not work
12-04-2012, 08:05 PM
will need to get my bloody volt meter out then... balls to it,why cant things be simple
so im assuming i need to take the plug off turn the car over and check theres voltage going to the plug?
12-04-2012, 08:08 PM
Connor Wrote:It was an intermittent fault, which screams electrical fault to me, as a mechanical part will either be fine and work, or be f*cked and not work Not necierally. Look at the old old fiestas. They had a problem with that. Problem is it was a box apart job to fix for a simple 30p part! I would start with continuity checks on the wires. I will send you over some auto data drawings and you can check for broken wires.
12-04-2012, 09:19 PM
ben is it a 3 plug ecu or a single plug?
12-04-2012, 09:37 PM
on a 3plug ecu
pin 2 wire M1620 on the speed sensor is ground it is linked to the MAF pin 3 wire 1410 its also linked to pin1 wire M1150 on the glowplug relay its also linked to the ecu two pins L4/M4 wire M1320/M1320 there is no earth connection other than through the ecu i would check the ecu earth and also the plugs and pins on the ecu for corrosion |
| Electrical woes | bashbarnard | 13 | 8,075 |
06-06-2017, 11:16 AM Last Post: bashbarnard |
| Electrical help!!! | Pompey306mark | 7 | 4,677 |
16-08-2014, 04:47 PM Last Post: Pompey306mark |
I got a electrical problem | tomosy10 | 9 | 5,909 |
19-03-2014, 12:29 PM Last Post: Razorback_Rob |
