06-07-2016, 08:16 PM
What's the max you can run a gt2052s at?
Gt2052s safe running pressure
06-07-2016, 08:20 PM
ran mine at 1.6 bar/23psi for many months fine. when i had my big pump on i uped it to 1.8bar/26psi and it was also fine. thats all i can tell you really. once id taken it off after almost a year of abuse it still had no movement or anything was in perfect working order
06-07-2016, 08:21 PM
Not more than 24psi for long life. Tiny little fragile shafts to make them spool so quick.
![]() I Don't Have A 306.
06-07-2016, 09:26 PM
Had mine at 25/26psi for over a year and still going ok with no issues. I just try to have a lot of mechanical sympathy.
06-07-2016, 09:28 PM
i was an arse to mine and it was fine
https://www.youtube.com/watch?v=zncJx-Bqb7c
06-07-2016, 10:25 PM
(This post was last modified: 06-07-2016, 10:25 PM by Danny Wideboy.)
I was an arse to mine and it snapped the shaft.
I have not got much mechanical sympathy. ![]() I Don't Have A 306.
07-07-2016, 06:47 AM
![]() 16.5:1 AFR, 170hp = 1.55bar ~18lb/min airflow. You're not going to want to run much more boost without falling off the end of the compressor map pretty severely. |
| Peugeot RHZ with GT2052s | MartinCartman | 20 | 16,699 |
27-11-2015, 04:25 PM Last Post: Poodle |
| Max safe power output of a DW10 | fattail95 | 2 | 2,804 |
14-02-2015, 08:52 PM Last Post: Poodle |
| Would this be safe? | JTaylor2005 | 4 | 2,763 |
01-01-2015, 03:43 PM Last Post: Poodle |
