Threads: 591
54
(19-02-2016, 03:20 PM)Matt-Rallye Wrote: Constructive criticism:
Too much umming and ahhing by yourself in the videos?
Yeah I realise I do it all the time. Appreciate the headsup though.
I am working on it.
I'm better at it when I am less rushed and plan a video better. Otherwise I'm winging it
Threads: 80
3
Car Model/Spec: hdi estate bus cherry red hdi
Given 2 thank(s) in 2 post(s)
glad to see that i wasn't on film
Threads: 591
54
(19-02-2016, 04:00 PM)daniel909 Wrote: glad to see that i wasn't on film
You are, just, in background!
Threads: 213
2
Car Model/Spec: HDI
Love the videos Piggy, needs more driving footage though! Could have shown some footage of that test drive after the new turbo was fitted, that would have been schweeeeet!
Threads: 591
54
(19-02-2016, 04:12 PM)MY95 Wrote: Love the videos Piggy, needs more driving footage though! Could have shown some footage of that test drive after the new turbo was fitted, that would have been schweeeeet!
Yeah working on it
Threads: 102
9
piggy I got the chance to watch the swirl pot install, thought that was a neat little upgrade there, only thing is why did you route the fuel lines through the cab, rather than just follow the Original lines? would that have been a f*ck on due to where the swirl pot was?
Threads: 591
54
28-02-2016, 08:24 AM
(This post was last modified: 28-02-2016, 08:25 AM by Piggy.)
(27-02-2016, 10:53 PM)procta Wrote: piggy I got the chance to watch the swirl pot install, thought that was a neat little upgrade there, only thing is why did you route the fuel lines through the cab, rather than just follow the Original lines? would that have been a f*ck on due to where the swirl pot was?
Yeah, lines just too big to bend and route that way, plus location and wanted to have them visible in cabin. Totally terrifyingly life threatening i'm sure someone will say... But then maybe my battery will kill me first
Soo....
Ruan spanked it...
Aaron loved it...
Crank pulley destroyed
Threads: 591
54
Oh. V odd. Its never been off since it was built...
Too much torques!?!?
I'm not really sure how to fix the issue
Threads: 82
27
Threads: 42
28
fit new key and pulley and bolt, job done.
as long as the crank isn't worn.
Threads: 591
54
See the crank pulley... Woodruff key smashed off in the slot
Threads: 386
87
Weld it on...
Seriously though, I've always thought woodruff keys look a bit small considering the forces that must go through them, not seen that happen before though!
Threads: 591
54
03-03-2016, 11:39 AM
(This post was last modified: 03-03-2016, 11:40 AM by Piggy.)
Woodruff keys only locate...its the massive bolt that holds the forces...
Which had come loose...which is odd,because as i say, its not been touched for some time
I may temporarily slam a replacement pulley on there and just threadlock the hell out the bolt and blast it in mega tight
Threads: 386
87
03-03-2016, 11:43 AM
(This post was last modified: 03-03-2016, 11:53 AM by Toms306.)
Ah, that makes sense!
Was it a new bolt used? I know they're only meant to be used once even though most of us probably re-use them.
Don't threadlock it in mega-tight, you'll never get it out again. Had a HDi where someone had done that, couldn't budge it with the gun or bar...scrapped the block with the bugger still stuck in eventually lol!
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
(03-03-2016, 11:43 AM)Toms306 Wrote: Don't threadlock it in mega-tight, you'll never get it out again. Had a HDi where someone had done that, couldn't budge it with the gun or bar...scrapped the block with the bugger still stuck in eventually lol!
Depends on the threadlock used - it's not all created equally!
Normal medium strength stuff is absolutely fine, but if you use the proper heavy duty stuff that needs heat to release then you're potentially stuffed.
Threads: 91
83
Loctite 243 only on that sorta stuff - anything else and you'll never get the fucker out.
Also don't go pouring the entire bottle on, as even if it releases, it's likely to crud up the threads so badly on the way out it'll jam before it actually comes out.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
Threads: 591
54
Tom (zxvolc) kindly dropped in a spare xud9 pulley last night...I kept him at a distance to spare him from our germs though... Can't describe how much it pained me to say no to his offer of a passenger seat run in his ZX... Sounded epic as he left though...
But thanks Tom. Found a spare newer crank bolt too...attached to a spare 2.2hdi crank!
So when I'm feeling better than death...will try n sort it
Threads: 49
2
Car Model/Spec: 306 HDI Estate + 205 HDI
Exact same happened on my 406, just fitted a new pulley making sure that the remains of the key were in line with the slot to allow it to sit flush against the crank sprocket.
Threads: 386
87
How have you caught something if you can't get out with a broken foot?
Threads: 591
54
Been out a bit...wife got same thing too so maybe she was the carrier! Ha
Threads: 386
87
Ah yeah, probably her fault then.
Threads: 541
124
Defo blame the wife.
Oh and just machine out the keyway and fit a bigger (custom made) woodruff key then nail the whole lot back together.
Threads: 591
54
Well that went well....
1.9 xud pulley does not fit a 2.1!
Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
Shitter mate.
Have you spoken to bash? He's got eleventy billion 2.1s kicking around.
I Don't Have A 306.
Threads: 371
29
Car Model/Spec: ford fiesta
(07-03-2016, 06:07 PM)Danny Wideboy Wrote: Shitter mate.
Havnt got a spare i went down and had a look got one pully for 2 engines lol
Threads: 541
124
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
may have missed something here whats wrong with a new item?
Threads: 591
54
(08-03-2016, 08:10 PM)Stef205 Wrote: may have missed something here whats wrong with a new item?
It's nearly £100.
Threads: 36
2
This project looks interesting, I'll have a proper read through in a bit.
Hope you get it sorted soon!
Threads: 102
9
