08-09-2015, 12:17 PM
dont get perspex, its shit and shatters.
get polycarb.
get polycarb.
SRowells Black Rallye
get polycarb.
25-09-2015, 08:46 AM
Repost from the 1.8 project... This is going on the 1.8 but im sure itll make its way onto the rallye once thats gone.
Well I collected a brand new piper stainless exhuast last night. Was bought for this guys track car but never fitted it. Same guy I bought the cooler off. It was up for £200 or offers on ebay so i offered 165 with 15pp. Ended up having to meet him half way to get it in time for the expo. These retail for £340 as far as I can see so looks like Ive almost paid half price. Not a pretty picture but there we have it. I just hope it fits over the magnex decat pipe. ![]() Hopefully going to get this fitted tonight.
26-09-2015, 09:19 AM
i have a piper system on my car, its a loud system I think, in fact I think I might bin it off and get a one made up, as its too loud for the road.
18-12-2015, 01:49 PM
Another shiny to put on the pile... I believe there was a group buy on these two years ago on gti6 owners. Apparently there were two batches. The first batch had no washers which meant the carbon would crack if over tightened. The second batch had copper washers between the carbon layers to stopped cracking. This is the first batch with no washers however it was £40 from Chris Harris and before that it was Sam Bates and was on his black rallye. Its a small world.
18-12-2015, 04:40 PM
Good find there mate! I want one of these at some point! And for £40 a good price!
18-12-2015, 05:38 PM
Ah so you bought it! (hate you)
19-12-2015, 08:41 AM
Yeah I wanted that as well haha.
Nice to see you have it I got it from some bloke off ebay breaking a car also got the carbon mirrors that had the same weave but dunno where they are now.
27-12-2015, 05:52 PM
After 5 pages the Rallye has moved from under the car port.
![]() First problem was the daft screw on battery terminal...bolted a quick release posi cable to it. ![]() ![]() Second problem was putting the window down...poking around the door card forgetting they're manual. ![]() But more importantly, it started on the first turn and drove straight out to turn round for beam replacement. Kept it idling until the fans cut in and it didn't leak at all, water level is the same now as before I ran it... There is a heavy knock though, is that a tappet (seems a bit heavy) or a crank pulley or something else? It had been running for over 15 mins when I took the vid... Note the dryness, and the knock... https://www.youtube.com/watch?v=xKI-c0Am...e=youtu.be Anyway, half way there with beam swap, rust has slowed progress there but hopefully will get that soon.
27-12-2015, 05:59 PM
Im putting money on that being a big end!
27-12-2015, 06:33 PM
Hmm, lets hope not!!
![]() Will have to get some thicker oil if it is.
27-12-2015, 06:36 PM
remember i set that beam to match the 5 door -60mm iirc it may want raising!
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
27-12-2015, 06:38 PM
(27-12-2015, 06:36 PM)Stef205 Wrote: remember i set that beam to match the 5 door -60mm iirc it may want raising! mine first!
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-12-2015, 06:43 PM
Hmm... I've never altered beam height, just swapped complete beams, that can be done once the beams on though right?
Also, the Rallye uses a brake bias valve, does the whole thing just get swapped on to the new beam? Oh, and the ARB wasn't fitted as there are 2, does that just get shoved in and bolted up?
27-12-2015, 06:47 PM
tom you knacked srowells rallye!
27-12-2015, 06:59 PM
Lol, for once it's not me breaking stuff!
27-12-2015, 07:09 PM
Yeh the arb just gets shoved in tom and plates bolted on each end. I'll have to bring a wire wheel over to get them cleaned up.
27-12-2015, 07:18 PM
When I swapped beams I pulled off all the pipes etc and swapped the bias straight over no issues
27-12-2015, 07:24 PM
dont pinch those bushes and seals!!!!!!!!!!! lots of grease and time!!!
27-12-2015, 07:51 PM
(This post was last modified: 27-12-2015, 08:47 PM by luke306rallye.
Edit Reason: Was wrong.
Bottom end.
27-12-2015, 07:59 PM
(27-12-2015, 07:18 PM)Matt Wrote: When I swapped beams I pulled off all the pipes etc and swapped the bias straight over no issues Good good, easy enough then. ![]() (27-12-2015, 07:24 PM)Stef205 Wrote: dont pinch those bushes and seals!!!!!!!!!!! lots of grease and time!!! That's a lot of exclamation marks. We'll be careful!
27-12-2015, 08:14 PM
27-12-2015, 08:15 PM
Yeah thats not valves. A "tapper" is a very distinctive sound and thats not it
27-12-2015, 08:29 PM
New bottom end required there..... Might as well pull the engine to replace it and sort the bulkhead hole while you are at it. I'm an amature and can have an engine out in less than an hour once the front end is stripped off.....
Then strip the interior and sell me your seats
this is valves kissing pistons
oh if you want an engine i have one here we could do a deal on
27-12-2015, 08:42 PM
(This post was last modified: 27-12-2015, 08:45 PM by luke306rallye.)
Sure its nothing simple like the crank pulley?
27-12-2015, 08:58 PM
more likely an inlet cam pulley
take the aux belt off and run it will prove the pulley https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-12-2015, 09:01 PM
Good idea, will try that.
Crank pullies rarely knock Tom. They rattle sometimes but not knock.
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft |
| Boring Black Rallye | wainwrightj | 57 | 44,579 |
06-02-2018, 03:38 PM Last Post: Mighty306 |
| SRowells 3D Printed Cup Holders | Eeyore | 17 | 13,078 |
08-01-2017, 07:04 PM Last Post: Magenta Sunset |
| SRowells Diablo 1.8 - Jenvey 45s & OMEX600 | Eeyore | 1,246 | 821,237 |
26-12-2015, 12:56 AM Last Post: procta |
