Wheel bolts for cyclones
Managed to get some cyclone wheels to replace the standard meridian ones, but the bots are different so if any 1 can help
Thanks
there are two types of clones
early set take a flat seated bolt that has no tapered shoulder
later clones have a counter bore in the bolt holes which accept the later bolts that have a shoulder which secures the steel spare wheel
[Image: c252475f-b5a1-415c-bfdc-b11b5d56087e.jpg]
GTI6 Info
ive got a set of the later ones inc locking bolts if you need them.
(08-03-2015, 07:51 AM)welshpug Wrote: ive got a set of the later ones inc locking bolts if you need them.
Which 1s are the later 1s mate?
later ones are the bolt on the left in the picture
GTI6 Info
I think it's the early set I need then mate, as the standard 1s off the meridian wheels I believe look like that then?
I thought it was the GTI ones that had just the flat seated bolts as the spare was an alloy, whereas the other type was off the meridians etc, and ran a steel spare hence the taper?
(08-03-2015, 06:22 PM)Jonny81191 Wrote: I thought it was the GTI ones that had just the flat seated bolts as the spare was an alloy, whereas the other type was off the meridians etc, and ran a steel spare hence the taper?
Yea I think it's the GTI bolts I need without the taper
You have a pm Smile
(09-03-2015, 10:44 PM)Dale Wrote: You have a pm Smile
They won't be able to reply to it, as they don't have enough posts. This seems a bit like a "Wanted" thread to me, so should be in the Wanted section, but then the OP can't post in there either due to lack of posts. Naughty naughty. Nospeak
Ooooo I see they best get posting in that case Confused
  Alloy Wheel Bolts rdstars 2 2,693 16-03-2017, 05:01 PM
Last Post: rdstars
  Wheel bolts PugRory 11 6,536 09-11-2015, 11:55 AM
Last Post: PugRory
  c5 steel/alloy wheel bolts Poodle 8 5,831 20-04-2015, 08:42 PM
Last Post: Poodle
