p bush upgrade
p bush upgrade
I need a new wishbone and ive read on here that the partner p bush is a good upgrade, can i just buy a partner wishbone to replace mine and then it should have the uprated bush fitted or will it not fit?
Think you need a bigger bolt there's a thread in it somewhere
Just get the partner p bushes fitted onto your current arm, genuine arms are heaps better than aftermarket ones which can fail, i had the front bush literally snap off at 50mph not cool
[Image: av5ym8.jpg]
How will i know if mine are oe as its an old car so may have had wishbones replaced in the past???
normaly the oe arms have bolts holding the balljoint on and the patern are rivited
GTI6 Info
Also which are the best p bush to buy as there are loads of different ones on ebay
(31-01-2015, 03:29 PM)cully Wrote: normaly the oe arms have bolts holding the balljoint on and the patern are rivited
Every pattern iv ever had had bolts and the OE ones had rivets Big Grin
o.e are not rivetted.
Wrong way round from what I have always seen
Ecp sell twr  partner p bushs and ocap ones has anyone used the ocap ones or should i just go for the twr's
  P Bush PocketFighter 7 5,002 09-08-2016, 04:47 PM
Last Post: PocketFighter
  Fitting new P bush Welshy_Pete 1 2,231 27-01-2014, 12:45 PM
Last Post: mcglynn
  how the f'ing f do the p bush big bolts go in? HDIkyle 17 10,466 23-08-2013, 01:58 PM
Last Post: Mattcheese31
