29-09-2014, 07:09 PM
If a separate battery solves it, why not just run it off a 9v battery on a switch, rather than a huge 12v car battery?
The Racetractor. The End.
(29-09-2014, 07:09 PM)zx_volcane Wrote: If a separate battery solves it, why not just run it off a 9v battery on a switch, rather than a huge 12v car battery? funnily enough I was considering that!!! But bit worried if it dies while on a journey! Still got that odd interference with the car despite no physical connections Wishes for more power...
29-09-2014, 07:13 PM
carry a spare innit
Common earth.
All sensors and the device to a common earthing point which ideally should be on the engine - cos it's what you take readings from. Plus all sensors etc should take power from a common point. Be careful that anything you are connecting doesn't have it's casing (if metal duh) earthed to the GND line and chassis at same time. It dosn't matter if that is a GND wire from the engine, point is that it's common. If it dont work like that, then 9/10 you aint doing it on one common point. Ditch the extra battery of course.
All the sensors have no relation to the engine earth. TPS, RPM and map all dont make any physical relation to earth as they are all powered sensors. If that makes sense!
But it all has one earth. Loom and arduino all share a perfect earth to chassis, about 12inches from the arduino box. Basically as an independent system it works fine. Use the cars power and earth and it goes mental Wishes for more power...
So what method are you using for RPM ? Not the alt then ?
MAP ok, generally they are plastic - occassionaly the mounting tabs has metal rings which are connected to the GND.... Is the TPS on the throttle lever ? Have you buzzed that to see if the GND on the pot isn't connected to the case ? It's good practise to use the power and ground from the engine for the ECU or sensors etc generally speaking. In simplystic terms, it's like hunting for a ground loop with a stereo amp. 1/5th of it is magic. So run power and GND from the engine. For the level and frequency that the sensor operates at the differential between the chassis and the engine could be substantial. Your mileage and that of others may vary. What are you using for the PSU on the setup ? Do you have a sinlge drop regulator or multiples ? 7805 ? Smoothing caps ?
29-09-2014, 08:06 PM
Gt101dc rpm power sensor. TPS could possible be grounding...will check. MAP is free of contact.
I was running power and GND from the engine...thats when I have my issues!!! Wishes for more power...
29-09-2014, 08:32 PM
In car 9v battery charger in the fag lighter then if the battery does die you've always got a spare on charge.
29-09-2014, 08:42 PM
I wana fix it though. Not find a temp bodge
29-09-2014, 08:59 PM
Nothing so permanent as a temporary repair.
30-09-2014, 01:43 PM
30-09-2014, 03:05 PM
Theres not much I havnt tried bud but I do really appreciate you trying to help
Anyone got ideas to clean up the car 12v?? Wishes for more power...
30-09-2014, 03:26 PM
Buck & Boost converter (switch mode not a linear reg) and a crap load of smoothing caps ?
30-09-2014, 04:41 PM
ideally you need to get a scope on and see what noise is there
01-10-2014, 02:20 PM
Is it weird that I am excited that some service bits arrived?!
Shell HX7 engine oil Fram slim/short oil filter Mann fuel fiters Will update with part numbers later for future ref but very happy that my new fuel filters cost less than the OEM ones...£1.74 each so I ordered 3! Hope to fit oil cooler when I do the service which I am less excited about (01-10-2014, 02:20 PM)nominous Wrote: I missed some earlier Qs you had. Im using two 12v regs to clean up the 12v input then a 7809 for the 9v power to the arduino from one of the 12v and a 7805 for all the sensors which use 5vs. No smoothing caps that I am aware of. Tbh I dont even know what a smoothing cap is. I assume its not an item of swimwear Wishes for more power...
01-10-2014, 09:57 PM
Going to be honest here and say i really CBA to read all of this but i have skimmed it. Am i understanding it right that you are getting it completely fault free when bypassing the 9v reg and just hooking up a 9v battery directly? Also, what is the 9v for? Sensor reference i assume?
01-10-2014, 10:02 PM
9v is for the arduino.
5v is for the sensors. I get it almost fault free when I simply use a 12v car battery sat behind my seat instead of the normally earth to chassis and live from the fuse box. So still using the regs. Wishes for more power...
01-10-2014, 10:09 PM
Ah ok i see. Its not really a proper fix but as a more permanent fix, you could try a noise isolator?
02-10-2014, 06:28 AM
(01-10-2014, 10:09 PM)Niall Wrote: Ah ok i see. Its not really a proper fix but as a more permanent fix, you could try a noise isolator? Ok...erm...whats one of those?! Wishes for more power...
02-10-2014, 07:13 AM
What size smoothing caps do you have on your regs?
Still think using two regs inline is pointless - what is the working headroom on them? All the info will be in the spec sheet for whatever IC you're using (02-10-2014, 07:13 AM)zx_volcane Wrote: What size smoothing caps do you have on your regs? Ok...still dont know what a smoothing cap is. Dont know what a IC is either Ruans suggestion to help with the poor electrics in my french shed was a 12v then to 9v and a seperate reg system for the sensors, so 12v then to a 5v. Cleaning up the 12vs as i understood it. Pointless or not, they are in there! A quick google tom and I dont have any smoothing caps, just some small capacitors in couple places as per diagrams for arduino vnt I found My current mess: [attachment=19320] Wishes for more power...
02-10-2014, 08:24 AM
(This post was last modified: 02-10-2014, 08:25 AM by zx_volcane.)
The best thing you can do is go away and read up on how it all works. Must be some online courses available on the basics.
I'm sure I keep suggesting to go through the Arduino tutorial examples or to build some small example circuits on breadboard. Get a good understanding of how voltage regs work - how capacitors work ..etc Find out why you need smoothing caps on the input and output stages of a reg, and how the values affect it. Build up some test circuit of simple things - a voltage reg would be a good start, or a variable voltage reg - test the outputs, stick an led on it or something, get some working knowledge at least. Rather than starting with a big complex system that you have no idea about, and getting frustrated when you can't fault find. Why do you think two voltage regs inline is going to be better than one? A voltage regulator either regulates the output voltage or it doesn't. Have you asked on the Arduino forum? Going to be lots of knowledge people on their and support. (02-10-2014, 07:30 AM)Piggy Wrote: Ok...still dont know what a smoothing cap is.
02-10-2014, 08:29 AM
The whole idea of a smoothing capacitor is as the name suggests. It smooths the wave form which you can view from a power source on an occiliscope. A capacitor is just a battery in basic terms. I'm sure you know what a DC wave form looks like so if you imagine when it's dropping, the capacitor which is inline of the power supply will take over and provide power until the do supply is restored. Obviously this happens very very quickly (typically measured in hertz).
If I were you I would look into how transformers work. They are a very simple device in theory and you should have a better idea then of what the electricity is doing at each stage through your transformers and why a smoothing capacitor is required
02-10-2014, 08:36 AM
This lad will show you the basics >
Yeah I know the whole wave thing with DC and AC currents.
You have told me a 100 times Tom. Im just busy and stubborn!! And to be honest I know I will suck at it. And i am so close to having this work I guess. Will try and find time tomorrow evening to start learning. Never got a reply on the arduino forum. That guy is metuuuuuool!!! Wishes for more power...
02-10-2014, 08:54 AM
ive used some thing like this on projects they seem to work ok you may need two though
http://www.ebay.co.uk/itm/New-300W-12A-D...2c8bb2b935
I checked the arduino forum and got a reply:
"1. If the sensors are all in the engine bay, then I suggest you ground to the Arduino and its voltage regulator to the car ground in the engine bay near the sensors, and nowhere else. 2. Put some filtering on the all the Arduino inputs, such as a 47K resistor in series with each Arduino input pin, and a 0.1uF capacitor between each input pin and Arduino ground." (02-10-2014, 08:54 AM)vincent1 Wrote: ive used some thing like this on projects they seem to work ok you may need two though Its a bit over kill for my needs bud, but thanks Wishes for more power...
