15-09-2014, 01:45 PM
Having no life whatsoever - that's how!
I don't know that much, I just tend to absorb information quite easily.
The Racetractor. The End.
15-09-2014, 02:34 PM
He is like a really nerdy Spongebob. Absorbs a lot.
15-09-2014, 03:17 PM
Cheers Jeff!
18-09-2014, 02:08 PM
I can almost imagine your car screaming "challange accepted"
18-09-2014, 02:13 PM
18-09-2014, 04:22 PM
Use t clamps , jubaliee clips don't apply pressure evenly so they clamp in a more oval shape than t clamps
Otika clips apply pressure pretty much perfectly around the pipe but can only be used once Its part of the reason you can't use jubaliee clips on gas hose and that they damage the hose more than they clamp it
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
18-09-2014, 04:55 PM
Too much hype about T clamps. Jubilees will tighten much more than a T clamp all day long...and are even so long as you select the right size for the right hose.
Its not leaking at those points. I think alloy inlet may have cracked Wishes for more power...
18-09-2014, 05:03 PM
How do you tighten jubliees more than Mikalors? I stripped loads of damn jubillees on the Golf SMIC pipes. Bought 3 Mikalors (only needed 2 but they're an arse to get the right size lol) and never had any more issues!
18-09-2014, 05:06 PM
Obviously cheep jubilees mate.
Genuine Jubilee or ASH stainless steel....they will cut through a hose before busting. Ive stripped loads of cheapo ones mind. Wishes for more power...
18-09-2014, 05:17 PM
Seriously...
Mikalor T Bars are grade A wank - they're even worse IMHO for not applying even pressure - you've got a massive gap where there's no clamp! Genuine Jubilee or Hi-Torq Jubilee clips will literally cut the silicon or crush the pipe before they screw up. I've never shagged a decent quality Jubilee - 35+lbs of boost on varying turbos and I've not had a problem with them... Had countless problems with Mikalors. Not to mention getting them on the twatting pipes will have me swearing in seconds.
18-09-2014, 05:23 PM
Ah fair enough, they were only cheap jubilee's tbf!
I still wouldn't say Mikalors are bad though, as said they cured my problem. Not saying a decent jubilee wouldn't have done just as well though!
19-09-2014, 09:38 AM
And pissed you off significantly less and if you actually put proper boost through it, leaked through the gap between where the threaded bar goes through..
Didn't leak for me, also didn't piss me off, no worse than fitting a jubilee when you get the right size.
19-09-2014, 09:47 AM
Just what I was taught, still think O clips (otika) are the best but that's cause you can control how the pressure is spread when you pinch them down but no one uses them cause can only be used once
Interesting to find out jubaliees are better than T clamps tho
19-09-2014, 10:08 AM
never had issues with tbolt clamps myself, always used them, nice bead, tbolt clamps, done.
19-09-2014, 10:21 AM
get some chemical metal on the mani
19-09-2014, 11:07 AM
Haha...I will be dropping the engine down and across a few MM this weekend, whipping the manifold off and replacing with my spare one and replacing the plastic one with a metal one too. Also going to blank off the EMP just in case its that also.
19-09-2014, 07:20 PM
Shame
19-09-2014, 07:21 PM
Spray clutch cleaner near where you think a leak is it will rev up when you spray it into the leak, might not work on a really tiny leak
Has done me well in the past Obviously have the engine running when you do this
19-09-2014, 07:23 PM
Carb cleaner for me...
Aint going to work with this leak. Only on boost Wishes for more power...
19-09-2014, 07:32 PM
Yeah wd40, deodorant and lighter fluid work to anything that burns
Could try an air compressor to pressurise the system then you'd be able to look around the engine bay for the noise
19-09-2014, 07:39 PM
Yeah...I got it covered mate.
And no, i wont be using wd40 or lighter fluid ![]() Wishes for more power...
19-09-2014, 07:43 PM
prob not an excellent idea spraying flammable liquids around a hot engine
19-09-2014, 07:46 PM
(19-09-2014, 07:43 PM)zx_volcane Wrote: prob not an excellent idea spraying flammable liquids around a hot engine Yeah, exactly....'oooo whats that flame thingy coming from my 500degree mani pipe?!' Tiz why I use carb cleaner in short sprays Wishes for more power...
19-09-2014, 09:07 PM
Lol and the joys of variable geometry turbos... No chance it'll be under vacuum anything off idle.
