Benefits of gti6 brakes
Don't waste your money, just stick with decent quality normal discs.
If I were you I'd get some decent discs with decent pads, mintex 1188 or green stuff or something, I'm gonna get normal discs when these need changing, they're more for show then anything. The braided lines and 6 master cylinder make a difference though
(13-08-2014, 04:03 PM)DazzaHDI Wrote: If I were you I'd get some decent discs with decent pads, mintex 1188 or green stuff or something, I'm gonna get normal discs when these need changing, they're more for show then anything. The braided lines and 6 master cylinder make a difference though
I'll have to have a look what would you class as decent disks and what does the 6 master cylinder look like?
get some standard disks from euro, but pop some decent pads in, plenty of threads with recommendations on here already.
If you're getting discs from ECP, go for pagid over the eischer ones, they are made much better and helps with the bedding in process
I just put some Delphi discs and pads on because they're decent plus damn good value.
Drilled and grooved discs are a waste of money and your pads on a standardish-power road car.
Drilling is for dissipating heat, and if you are overheating the brakes enough for drilled discs on the road you are driving like a cock.
Grooves are for skimming the top layer off of very hot brake pads to remove the near-molten, softened pad material from VERY hot brake pads, this reduces brake fade. Again, your brake pads should not be molten on the road.
The only advantage is that grooves can increase the initial bite. However, skimming the pads every rotation also increases pad wear.
To summarise, you will have 0.1% better brakes with drilled and grooved disks if you aren't braking hard constantly on track, for higher cost and shorter pad life. Gti6 brakes with good quality discs and pads are more than enough to lock the wheels. You would do better to have good quality brakes, and put the extra into better tyres for better stopping power.
62k Diablo Phase 1 Gti-6:
Project Thread
(14-08-2014, 08:16 AM)RetroPug Wrote: Drilled and grooved discs are a waste of money and your pads on a standardish-power road car.
Thanks for the summary, that's helped Smile I'll just get good quality standard disks and some green stuff pads when I need to replace them. I want to strip the calliper's and repaint them is there a guid on stripping the calliper's?
No worries. I've never used them, but others have had bad experiences with green stuff:
http://306oc.co.uk/forum/thread-25638.html
Not sure whether or not there is a guide but I have seen threads on it. Big Red (I think) do caliper rebuild kits at reasonable prices, think they can be found on ebay but not sure. Give it a google and have a search through on here.
Project Thread
(14-08-2014, 10:15 AM)RetroPug Wrote: No worries. I've never used them, but others have had bad experiences with green stuff:
Yeah I've just checked out Big Red, seem pretty reasonable Smile I'll have to do it when I don't need the car for a few days
(13-08-2014, 02:21 PM)DazzaHDI Wrote: They're 6 brakes ThumbsUp
Here's mine Smile
Stupid iphone! Angry
Arent those discs on the wrong side ?
For the disks and pads on general fast road/occasional track use, I'd recommend Pagid TBH. They're damn good value for what they are, basically very good quality OE spec.
Disks:
http://www.eurocarparts.com/ecp/c/Peugeo...b7e&000027
Pads:
http://www.eurocarparts.com/ecp/c/Peugeo...462&000036
(14-08-2014, 07:20 PM)Jonny81191 Wrote: For the disks and pads on general fast road/occasional track use, I'd recommend Pagid TBH. They're damn good value for what they are, basically very good quality OE spec.
Disks:
Pads:
Thanks man Smile I'll get them when they need replacing guessing the price of the disks are for 1? And pads are for a front set?
Disks:
Pads:
Second that. I used Pagid stuff for a while and was spot on!
Disks:
Pads:
Yeah I'll go for them Smile really great price
Also use Pagid...mainly cos the discs look pretty. Makeup
But seriously, always seem to have issues with Eicher, either squealing or warping, but Pagid have been fine every time! Smile
Yeah I bought eicher last time and they took a huge amount longer to bed in than other discs I've had.. will definitely be going pagid next time!
Can get a set of Mintex discs and pads for all corners on ebay for not much. They're not 1144's but still seem to work good enough.
I'll try to find a link later.
http://www.ebay.co.uk/itm/PEUGEOT-306-GT...4cee41cabe
Get 4 pots.
/Thread
Team Cyril
(15-08-2014, 08:28 AM)Toms306 Wrote: Also use Pagid...mainly cos the discs look pretty. Makeup
Yeah I think my current discs are warped the front right rubs at a curtain point
(15-08-2014, 08:53 AM)bigcheez2k3 Wrote: Can get a set of Mintex discs and pads for all corners on ebay for not much. They're not 1144's but still seem to work good enough.
That seems like a pretty good deal I'll have to price up pagid for all corners and see what works out cheaper Smile
(15-08-2014, 09:44 AM)Matt-Rallye Wrote: Get 4 pots.
/Thread
I'd love to! But don't think I'll need them for road/occasional track use
/Thread
Maybe slight overkill but no-one has ever died from having brakes that were too good..
Team Cyril
Here's mine Smile
Dazza looks like your discs are on the wrong side??
Lots of talk about upping the size of front brakes or putting gti6 brakes on but as anyone considered 406 hdi brakes? or am I missing something? They're the same size as gti6 up front but they appear a good bit bigger on the back. Are the 306's too light on the tail for the bigger rear bakes?
(26-08-2014, 09:11 PM)Will Wrote: Lots of talk about upping the size of front brakes or putting gti6 brakes on but as anyone considered 406 hdi brakes? or am I missing something? They're the same size as gti6 up front but they appear a good bit bigger on the back. Are the 306's too light on the tail for the bigger rear bakes?
IIRC Dum-Dum did this.
They benefit from a larger piston size in the front callipers from memory.
Apologies if I double over a topic, only new and trying my best not to :S do you know are the bigger back brakes suitable or do they over do it?
Never looked into it mate.
As long as the brakes physically fit, and the bias remains reasonably similar, then it will be fine.
If you are changing both the front and rear brakes, the bias should be fine.
Things to consider would be rear disc diameter (will they fit under the wheels once the callipers are over them(which I imagine they would)) and if the mountings are compatible.
Tbh it's probably overkill for anything less than a track weapon, my back end gets happy when braking heavily with standard rear brakes, as you say there just isn't the weight over the back in 306s.
If you have a large budget, go for it, but decent pads and disks in standard brakes + the best tyres you can afford will stop you better than a big brake conversion and not so great tyres.
Project Thread
Tbh id just refresh the rear calipers and leave be. The rears don't really so much stopping at all (probably 20% overall max) but are more there to help keep the car in shape under heavy braking. It's the fronts which do the majority of the stopping!
Tyres.
Most people put huge brakes on then search and search for the cheapest tyres to put on. Complete lack of the understanding of grip and where to spend the money.
Well serviced brakes and decent tyres will out brake gti6 brakes wacked on for £50 and budget tyres!
Cant ever imagine you would need bigger rear calipers unless you have more weight in the back regualarly or mid engine/rear engine conversion, RWD or 4WD
  GTI180 vs GTI6 Brakes MY95 18 7,657 19-11-2015, 09:29 AM
Last Post: Anton
  Gti6 brakes connorp 10 4,993 27-05-2015, 03:55 PM
Last Post: connorp
  GTI6 283mm Brakes Setup MY95 6 5,139 06-07-2014, 06:31 PM
Last Post: Sambarker
