GTI6 283mm Brakes Setup
I will be going stage 2 sometime in the near future and even at stage 1 my 266mm brakes are a bit dodgey, especially in the wet.
What is needed to switch from the 266mm HDI setup to the 283mm GTI6 setup, Ive had a go with the 283 and they are soo much better than my 266mm HDI setup.
Do I just need;
Callipers
Pads
Discs
Is the master cylinder really needed?
Also do I need the calliper carriers from the GTI6 or will my HDI ones work?
Cheers
Callipers, carrier bolts, pads, discs.
Should be fine on HDi MC (I find the GTi one is too bitey/sharp).
Big improvement over HDi's.
My S14 only has 280mm's (4 pots however)!
Cheers! So you can keep the calliper carriers but just need to buy the carrier bolts from the GTI6?
Sounds as if the 307 HDI have a similar 283mm setup to the GTI6 (307 ep 26 and GTI6 ep 22), worth going for the 307 HDI ones as they are supposed to be cheaper and sound like they would brake a bit better?
I have a xsara vtr setup for sale which is 283mm
(27-06-2014, 09:23 AM)MY95 Wrote: Cheers! So you can keep the calliper carriers but just need to buy the carrier bolts from the GTI6?
No you need the carriers too Smile
Cheers for the info! Smile
(05-07-2014, 10:46 PM)Sambarker Wrote: I have a xsara vtr setup for sale which is 283mm
Currently got a set sorted but if it falls through how much are you wanting for the set? I pressume they are similar to the GTI6 setup?
It will be identical. Wanting £30 inc discs and pads but not much life left in the discs/pads
  Upgrading to 283mm brakes on Dturbo Hobo Ash 15 8,470 01-07-2017, 11:34 AM
Last Post: Hobo Ash
  283mm 307 Brakes on a S16 Pingaz 13 8,416 05-10-2016, 07:46 PM
Last Post: miles
  GTI180 vs GTI6 Brakes MY95 18 8,491 19-11-2015, 09:29 AM
Last Post: Anton
