14-03-2014, 07:54 PM
ayeeee its on the to do list mate, main thing atm is making sure the motors good.
Bianca xud GT20
14-03-2014, 10:54 PM
Keep spraying stuff with wd40 till the wine stops once it's stops you no it's the last thing you sprayed with oil
17-03-2014, 08:46 PM
17-03-2014, 09:00 PM
(17-03-2014, 08:46 PM)zx_volcane Wrote:(17-03-2014, 08:30 PM)padge Wrote: heads pressurising up again, 90-95c cold heaters.. yeah, this....can't see why it would blow again!? Wishes for more power...
17-03-2014, 09:26 PM
Scrap it
17-03-2014, 09:30 PM
tbh, torqueing the headbolts down with a breaker bar probably didn't help..
17-03-2014, 09:44 PM
(17-03-2014, 09:00 PM)Piggy Wrote:(17-03-2014, 08:46 PM)zx_volcane Wrote:(17-03-2014, 08:30 PM)padge Wrote: heads pressurising up again, 90-95c cold heaters.. This wasn't done But if you find money there's the head off my engine ready to go would even lend a hand if needed to fit it.
17-03-2014, 09:47 PM
(17-03-2014, 09:30 PM)padge Wrote: tbh, torqueing the headbolts down with a breaker bar probably didn't help.. I bet that didnt effect it that much. If your worried torque them down a bit more. If you followed the stages guessing then done the angles aswell you cant be "that" far off lol :p
17-03-2014, 09:49 PM
nippy to dannys tomorrow, to torque them all down properly, it only started doing it after a harsh pull off from a junction lol.
17-03-2014, 09:50 PM
have you tried re-torqueing them?
might give you a bit more life
If they weren't torqued down at all that's pretty crazy. The final stage has to be done with a breaker bar but not the first 2.
17-03-2014, 09:57 PM
Yeah that'll do! I have a torque wrench here i never use, shame it would be a pain to lend it to you!
18-03-2014, 12:12 PM
went out to check the water, and there was none even in it, went to top it up and the water just fell out the bottom of the rad, so looks like I just need a new rad.
18-03-2014, 12:26 PM
Phew!!!!
But doesnt explain the pressurising?! Wishes for more power...
18-03-2014, 03:59 PM
Nevermind still doing it opened top bleed screw near matrix and water blasts out of there
18-03-2014, 04:12 PM
Rad has probably popped because its pressurising mate...I had similar on my red one, blew bottom hose off.
18-03-2014, 04:37 PM
One of the small pipes had come off, put it back on put water in it and it still pressures up, going to try torquing bolts down properly tomorrow, if thats no good, then time for another hg lol..
21-03-2014, 07:59 PM
Head is now off this, will be dropping it off for skimming/testing monday/tuesday and should be built back up thursday
21-03-2014, 08:03 PM
good to see your keeping it and fixing it again im sure it will be worth it.
![]() bout time you coded the side strips tho haha :p
22-03-2014, 12:01 AM
Getting there Kyle, i know what your feeling all to well! It will be back soon and it will be epic!
| Garrett GT20 Project | 306Puggy | 179 | 148,112 |
22-10-2013, 06:56 AM Last Post: Scott |
