Pinch bolt torque?
After Christmas i will be fitting a new drivers side hub. I have found the torque figure for the ball joint pinch bolt( 23 lb ft), but can find the correct torque for the pinch bolt that joins the hub to the shock. Does anyone know what it should be please. The car is a 2001 HDI if that makes any difference.
Cheers Titch
Should be the same as a 205 which is 58nm (43lbft)
(24-12-2013, 12:39 PM)Paul_13 Wrote: Should be the same as a 205 which is 58nm (43lbft)
Nice one thanks,
Going to have to borrow a bigger torque wrench off my old man then
Titch
Just make sure you do the ball joint pinch bolt to 35nm or it'll result in an ovalled hub!
(24-12-2013, 12:43 PM)Paul_13 Wrote: Just make sure you do the ball joint pinch bolt to 35nm or it'll result in an ovalled hub!
Yeah that's why i am changing it, it has ovalled ! probably me that over tightened it Blush
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,680 04-01-2018, 11:40 AM
Last Post: Mighty306
  hub pinch bolt spec rd070707 4 3,574 22-02-2014, 07:49 PM
Last Post: swampy
  HUB: shock pinch bolt puglove 15 9,542 04-08-2013, 02:53 PM
Last Post: puglove
