Eccentric driveshaft intermediate bearing bolts
From what I can tell, as long as the driveshaft is in the hub, these bolts don't really do anything:
[Image: P1010033_zps4cf69727.jpg]
I've been undoing them for the last hour with a stubby 11mm spanner. If someone where to mislay them or simply forget to put them back would it be flagged up on MOT?
You definitely need them back in, and done up tight
Sad ___
Are you pulling them through so it doesnt all spin?
yup there there to stop the bearing spinning in the housing you dont want that Wink
(06-07-2013, 04:56 PM)Seb_Ryan Wrote: Are you pulling them through so it doesnt all spin?
As in, they won't rotate 360 degrees? Yes, I do but sometimes I find that the tap is the wrong way round because when I was tightening the nut it jumped out and then I have to untighten them and retighten them all again which is a pain. Which was why I was wondering if it was possible to get rid of them but I guess not. A "long" nut such as this one might be a nice thing to get next time though:
Or just use a deep socket or rachet spanner Wink
fiddly job.
Finger on the back so it sits in its seat, keep at it. itsa long thread...
but its there for a reason
Well I tightened them up in the end. If they can't rotate 360 degrees then does that mean they are seated? Just realised I can't see shit when the driveshaft bearing is in the way!
What cully said
[Image: sigi-2.png]
Haha he got banned again?
  306 Compbrake Eccentric Top Mounts Eeyore 6 3,292 02-10-2014, 08:19 PM
  O/S driveshaft support bearing phil clark 11 7,314 16-03-2014, 11:51 AM
Last Post: phil clark
  Drivers side driveshaft bearing stuck HDIkyle 4 4,296 17-02-2014, 05:09 PM
Last Post: Danny2009
