Drivers side driveshaft bearing stuck
Loosened both nuts obviously but its not judging. Giving it a good beating its starting to mash it up where it comes tho the engine mount. Anyone any ideas?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(16-02-2014, 01:35 PM)HDIkyle Wrote: Loosened both nuts obviously but its not judging. Giving it a good beating its starting to mash it up where it comes tho the engine mount. Anyone any ideas?
are you 100% sure that you have turned the bolts through 180 as i had similar issues on mine, i had loosened the nuts and turned the bolts enough so i thought but one was still catching so it wouldn't budge.
Ye positive I can see them but even if they had turned back it would come out so far then stop. It's not moved a mm so far its just chewing the bearing up
Blaze 1.6 Dead
You need a bigger hammer.
As Tom said, big flat blade/chisel just under the shaft too of the bearing so you don't damage the bearing and mount and smack It with a big hammer will come out
Team Doesn't own a 306
  drivers side engine mount problem 1.9 dturbo xluhxzy 3 4,095 10-04-2019, 07:45 PM
Last Post: Mighty306
Question driver side driveshaft removal help please? Mattcheese31 9 6,526 07-08-2016, 12:26 AM
Last Post: Mattcheese31
  O/S driveshaft support bearing phil clark 11 7,448 16-03-2014, 11:51 AM
Last Post: phil clark
