18-01-2012, 06:23 PM
Does anyone have any tips on removing locking wheel nuts without the key I have the good old socket and hammer but not enough room between rim and nut any suggestions woul be great
locking wheel nuts
18-01-2012, 06:28 PM
Do you no the make of them? Might be worth trying to find the replacement socket otherwise it will be a pig of a job
![]() 306 HDI, soon to be XUD
18-01-2012, 06:38 PM
if its the ones with splines on the side, try smash a 19mm socket (or whatever is just to small) onto it
18-01-2012, 06:55 PM
You could try a gator grip socket (wish i had the money for a set of these)
http://www.ebay.co.uk/itm/Gator-Grip-ET ... _500wt_949 Or a locking wheel nut removal tool/socket http://www.ebay.co.uk/itm/SCARFELL-7-PI ... _523wt_698
18-01-2012, 07:09 PM
Them gator grip things are fecking useless, my bud who runs a tyre place, got a set first time he used it all the splines bent and fell out got a replacement that lasted 3 uses so just got his money back. Best bet is get something welded to it
18-01-2012, 07:25 PM
Chisel and a large hammer
18-01-2012, 07:30 PM
Thans for the advice recently bought a stick welder never gived it a thought just hope the weld will hold it enough to crack the nuts off
My local garage will do them for 25quid a wheel f*ck that :o
18-01-2012, 07:33 PM
25 quid robbing gets got mine drilled out for a tenner
19-01-2012, 05:15 PM
Locking wheel nut remover kit from snapon
19-01-2012, 05:29 PM
Im with jonny, those sockets are complete wank on anything done up more than finger tight, try welding something on the end, will be your best bet
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]() |
| Locking wheel nut key.....f@c# you, you bar steward. | turkish | 30 | 16,610 |
02-04-2014, 08:29 PM Last Post: SupaStar88 |
| F**King locking Wheel nuts :@ | Chris_90 | 18 | 11,122 |
28-08-2012, 11:24 PM Last Post: Chris_90 |
| help with choosing locking wheel nuts | kingy | 20 | 10,292 |
06-06-2012, 08:09 AM Last Post: kentiiboii |
