Threads: 1
I have a 1999 306 that needs the handbrake adjusted...I took off the center console to find the adjusting nut and for some reason there is none there. The car is a 1.4 meridan. It is supposed to be where the ashtray is. Could it be elsewhere, also the rear brakes are pads and not disc.
Threads: 28
Car Model/Spec: Phase 4 Silver HDi Estate
look under the carpet by the handbrake it is under a flap
Threads: 27
20
Best off adjusting each cable on the drum! But you can do it behind handbrake! Take the canter console out, little flap under the handbrake, nut under there! Take ashtray out and there is a nut there also, then you'll see adjuster at the back of the lever
yeah first unwind the nut under the centre console...
then properly adjust the shoes at the drums...then take the slack up in the cables with the nut.
81
I always just tightended the bolt at the rear of the second lower centre console section.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
It's actually the only way if you have a disc beam piggy. There's no adjustment on the calipers.
depends whats happening...if its after a pad/and or discs change...I dont adjust the cable or use handbrake for few miles to allow the auto adjusters to click into place as they bed in...
then the cable.
But thats just me.
Just wish the calipers, like a few other manufacturers, had external adjustment screws.
Threads: 28
after you've changed rear discs/pads you have to pump brake pedal before using handbrake or you fubar the mech
