Camber adjusting bolts for 306?
Hi guys I was thinking about cambering my wheels is there a bolt or set anyone knows about that will fit 306s any help appreciated.
you cant camber the rear and adjustable top mounts for the front
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
actually you can camber the rear, but it involves having the trailing arms machined.
^^^ What Jonny 81191118299192837472921119222911 said.
A company called BakerBM machine the trailing arms to camber the rear. IIRC it is circa £200 for this to be done.
Eccentric top mounts, or fully adjustable topmounts for the fronts.
Best thing you will ever do to your 306 Big Grin
or just buy a fecked beam?
Which has so much play in it, it handles like the pedophiles disabled dog in family guy.
Not fun, Ive been there lol.
Solid rear mounts for the win too!
Anyhow
Topmounts
[Image: 0aa16191.jpg]
Maximuim camber you can run without chopping turrets around:
[Image: 0631024e.jpg]
and the sarcasm was lost over the internet.. again.
best bit is, those top mounts grant have are only £135 brand new from spoox.
and jonny, on the internet, you always lose.
and you're short.
and northern.
just sayin...
and you drive a supertanker.
and that, is winning.
i can be seen from space, deffo winning!
but you also need an aicraft control tower to park it, and it has the handling of a bendy bus. And that, is failing.
actually, it doesnt handle too badly. tap the brakes before you turn in, helps the front bite and the back slip a lil Big Grin
but either way, hooning a volvo estate, is winning
  Camber/axle swap panzer 2 2,260 17-07-2015, 11:01 PM
Last Post: Stef205
  Negative Camber Snell 16 8,200 18-01-2015, 05:35 PM
Last Post: Snell
  adjusting rear drums philpemberton94 12 6,034 19-09-2014, 01:42 PM
Last Post: philpemberton94
