Lambda Sensor
Lambda Sensor
Morning Chaps,
need to get this one sorted out fairly pronto as my existing lambda is buggered to the point of having to run with it unplugged...
http://www.lambdasensor.co.uk/main/ntkpr...OZA527-E17
http://www.ebay.co.uk/itm/NGK-Front-Lamb...231fbd3751
Are these the correct sensors? Should I buy the one from Ebay, or does anyone get a sweet discount on them elsewhere that I can take advantage of in return for cuddles and/or a cheeky bum?
Just get a Bosch one. Should be cheap from Ecp with the discount code.
ecp dont have any for my car though; checked this morning on the interwebbzz?
Hunt for a genuine one though, i'd never trust pattern lambdas after previous experience
clicky
Are NTK not genuine?? I thought they were??
Nah Bosch are the genuine ones iirc
Any ideas what the difference between these Lambdas are?
(Bosch Part numbers)
0258003717
0258003716
I don't trust ECP as far as I can throw them; they've said the part number is 0258003716, but I don't trust the Scot either, who says it's 0258003717...
Different wire lengths iirc. Early GTi's had a longer wire than the later ones. But couldn't tell you the difference from the part numbers. There were definitely two different wire lengths though.
http://www.lambdasensor.com/main/bosch/p...0258003716
http://www.lambdasensor.com/main/bosch/p...0258003717
That seems to correspond on the basis of the above links, I was just a bit put off as when I just ebayed that bosch part number it came out with lambdas for smaller engines for the 306 (1.1, 1.6, 1.8, and some 106's, including 1.4 & 1.6 engines). Just didn't want to get one to the wrong spec, and I just know how tragic ECP are at getting the right parts in first time...
lmao f*ck off that seems to correspond, i DO have useful gti6 info you muppet
I just prefer to troll first
  GTi 6 Lambda Fault Toms306 24 11,501 30-04-2016, 06:09 PM
Last Post: Toms306
  lambda sensor willJspears 5 2,690 02-04-2014, 08:55 PM
Last Post: eddy_gti6
  Lambda sensor location Daniel306 3 2,713 18-12-2013, 04:00 PM
Last Post: Daniel306
