Can i change to the bigger ABS style drums without changing the whole beam?
As about, I was to get some of the much bigger drums that seem to be on ABS models from what i have seen. Can i just change the drums and setup without having to swap beams?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
You'll obviously have to change the backing plates too, but theres also a difference in stub shaft lengths. I'm not sure what has what, but I know I tried it and the hub nut wouldn't go on enough, ie the smaller drum hub had a shorter shaft. Might be easier to change the whole beam?
  Rear beam change LironTurbo 11 6,555 21-07-2017, 02:30 PM
Last Post: Mighty306
  Rear axle - drums to disc Dreijers 9 5,549 18-08-2016, 10:42 PM
Last Post: xanax
  steering wheel not straight after beam change/new tyres Iaitoo 16 8,525 13-06-2016, 05:58 AM
