Rear axle - drums to disc
Hi!
If I can get a drum brake rear axle and i have disc brakes in rear, is it possible to make drum brakes dissapear and disc brakes appear?
My car probably had abs, but it isnot working and I am not too bothered to sort it out!
And if I look citroen direction, what model I should seek for rear axle repalcement?
I need to know this because it is hard to get disc brake rear axle to rebuild. Since rear axle on my car is starting to act like it would be failing.
If you have a rear axel that it fecked that is disc for the trailing arms then yes as I found a very good drum axel pressed the good tubes out of the drum trailing arms then back into the disc arms and jobs doneĀ
thank you! if everything goes to plan, then I might start project thrad since MOT will be soon, lots of small repairs!
Remember some drum axles had poorer spec with torsion bar and arb size. Also stub axles are different drum to disc.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Tomorrow I will go and see rear beam from hdi hatch year 2000 with disc brakes as well, so might be my lucky day!
Hi, sorry but i don't quite understand, can you interchange (mismatch) the arms (brake or drum) from different axles?
For example, original drum axle with disc's arms instead and disc (probably harder) torsion bars.
No one?
Yeah you can do that, ive put drum arms on a disc axle when i rebuilt one as i wanted to maintain the drums and cross tube was better
Thx, that's what i will probably do, but have to open both axle's and compare witch one is in better condition.
Also.... the brake line splitter from the drum axle can be ported over the disc one (it doesn't have one)?
  Rear stub axle sizes weka 2 4,006 26-04-2019, 06:18 PM
Last Post: weka
  rear axle joe67 4 5,059 25-04-2018, 08:38 PM
Last Post: carlukepeugeot
  rear axle beam tube quality dsm482 10 8,226 22-12-2017, 02:01 AM
Last Post: dsm482
